[OpenLayers-Users] How to insert that I digitized Feture in my WFS layer?
ironbar joki_frei at yahoo.com
Wed Nov 19 09:45:47 EST 2008
I have been reading this example for some time but still I cannot figure out
where is the part (line) where a created featur get inserted in a wfs layer.
Alexandre Dube wrote:
> Well, I don't know any other way if there are.  Maybe someone else could
> help you for that matter.
> But, you should take some time to read the whole example and try it.
> You would discover a not so hard way to use WFS-Transactions.
> Cheers,
> Alexandre
> ironbar wrote:
>> Thanks for the answer: I saw the wfs transaction example that you
>> mentioned
>> but still I can not figure out the connection between a created feature
>> and
>> a wfs layer in which I want to insert my feature. I simply would like to
>> see
>> what is the simplest code for inserting a feature to a wfs layer. That is
>> why I posted the snippet that I thought is the simplest way for
>> implementing
>> a wfs transaction.
>> I hope that there is a simpler way to perform wfs transactions than as it
>> is
>> given in mentioned example.
>>> Hi,
>>>   Check out the WFS-T example in this sandbox to see a way of doing it
>>> with the WFS protocol :
>>> http://svn.openlayers.org/sandbox/topp/wfs/examples/wfs-protocol-transactions.html
>>>   Download this svn version and try it.  Hope this helps.
>>> Best regards,
>>> Alexandre
>>> ironbar wrote:
>>>> Dear all,
>>>> Here is a snippet of my code:
>>>> var wfsl= new OpenLayers.Layer.WFS( "MY WFS",
>>>> 			                    "http://localhost/geoserver/wfs?",
>>>> 			                    {typename: 'topp:mywfs'},
>>>>                                                        { typename:
>>>> 'topp:mywfs'  });
>>>> var wff= new OpenLayers.Format.WFS({layerName:'topp:mywfs'},wfsl);
>>>> feature.state = OpenLayers.State.INSERT;
>>>> wff.insert(feature);
>>>> I simply want to insert the feature in my wfs layer but what I get is
>>>> "An attempt was made to create or change an object in a way which is
>>>> incorrect with regard to namespaces" code: 14"
>>>> I would like simply to find a way how to perform wfs transactions using
>>>> an
>>>> imported wfs layer and feature that I created using openlayers example
>>>> "vector-formats".
>>>> Thank you
>>> Alexandre Dubé
>>> Mapgears
>>> www.mapgears.com
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
View this message in context: http://n2.nabble.com/How-to-insert-that-I-digitized-Feture-in-my-WFS-layer--tp1518519p1519322.html
