[OpenLayers-Users] Question on changing Popups on Textlayer
Christopher Schmidt crschmidt at metacarta.com
Wed Nov 19 13:18:18 EST 2008
On Wed, Nov 19, 2008 at 06:59:51PM +0100, Dirk Umlauffd wrote:
> Hello Christopher,
> The error message is gone now that I updated to 2.7 but:
> There are no markers on the map when I use OpenLayers.Layers.GML
Do you have iconSize and iconOffset in your textfile?
http://trac.openlayers.org/ticket/1844
> any help is appeciated.
> best regards
> Dirk
> Am Montag 17 November 2008 schrieb Christopher Schmidt:
> > On Mon, Nov 17, 2008 at 08:03:10PM +0100, Dirk Umlauffd wrote:
> > > Hello Christopher,
> > > I'm not quite sure if this will work - could you please have a look at:
> > > http://dtumlauffd.mine.nu/tmp_test/kopie_textseite.html
> > > http://dtumlauffd.mine.nu/tmp_test/kopie1_textseite.html
> > > The first one is working, the second one not - the second one is made with the OpenLayers.Layer.GML example.
> > > Both with the same textfile in the same location.
> > > With the second one I recieve:
> > > Your browser does not support vector rendering. Currently supported renderers are:
> > > SVG
> > > VML
> > > I use Firefox Version 3.0.3
> > What version of OpenLayers? Sounds like you're out of date -- running
> > something older than 2.6.
> > Regards,
Christopher Schmidt
MetaCarta
