[OpenLayers-Users] Using shp-files dynamically
Simone Giannecchini simone.giannecchini at geo-solutions.it
Thu Nov 20 07:35:26 EST 2008
Notice that it is possible to upload shapefiles to the geoserver
directly via the experimental REST interface. It might be worth
exploring that route.
Simone.
Eng. Simone Giannecchini
GeoSolutions S.A.S.
Owner - Software Engineer
Via Carignoni 51
55041  Camaiore (LU)
Italy
phone: +39 0584983027
fax:      +39 0584983027
mob:    +39 333 8128928
http://www.geo-solutions.it
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Thu, Nov 20, 2008 at 1:01 PM, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
> Hi,
> maybe after user uploads the file, you just run shp2pgsql that uploads
> it into PostGis and u displays it inside OL with little bit of
> filtering (for en example CQL_FILTER=shpfilename=name That is one of
> the simpliest solutions i could come up in 1 minute...
> Regards,
> Ivan
> On Thu, Nov 20, 2008 at 12:36 PM, Lehtonen, Mika <mika at digikartta.net> wrote:
>> I would be glad if I could get someone's opinion on the following matter:
>> This is also business related, which I guess is a little unusual in this
>> list. I won't be carrying on these questions, forgive me this. The
>> innermost is still technical.
>> My client has a light WebGIS system which has been carried out with
>> Openlayers, GeoServer and PostGIS as a backend. Now he would want me to
>> build an extension to his system where end-users could upload their own
>> shp-files into it. Just upload and start to use them, that simple. I
>> guess the shps' are mainly points, and quite simple. The end-users are
>> ordinary PC-users, so no complicated phases can be accepted.
>> We are having a huge gorge between our thoughts of how much this would
>> take hours to implement. My client claims that this is a matter of
>> adding a simple layer into their system and that's why it couldn't
>> possibly take more than a day or two at most. And in that case, it's
>> better be perfect. I said, on the other hand,  that I could build
>> something in a week, that would fulfil the most of the demand, but that
>> I'm not sure yet if this is something that is feasible.
>> So, what do you think? Any ideas what would be the best approach in
>> order to carry out this?
>> - mika -
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
> Users mailing list
