[OpenLayers-Users] problem with setting projections
kuba rojekk at gmail.com
Fri Nov 21 13:41:45 EST 2008
Hi!!
  I would like to display my shp data in other Projection than "EPSG:
4326"(WGS 84). Basically i am interested to show it in following
projections "EPSG:3395"(World Mercator) or "EPSG:3395"(Google
Mercator). I have set up Geoserver where i store two copies of the
same polygons(one in "EPSG:3395"(World Mercator) projection and
second  in default "EPSG:4326"(WGS 84) ).  When i look at the data in
preview they are correctly projected.I have tried to show both using
OpenLayers, but i could have managed to do that for "EPSG:4326"(WGS
84). When i only try to change the projection of  the map or layer for
EPSG:3395"(World Mercator, than nothing can be seen. There is no bug
or any Error. I have check it with firebug.
This code allows me to generate the map but the projection of
displayed map is on the one that i want to have. it is Always
WGS84(EPSG:4326") and it does not matter what kind projection have the
data stored on Geoserver.
Shp in world mercator projection
map = new OpenLayers.Map( 'map' );
layer = new OpenLayers.Layer.WMS( "Europ", "http://localhost:8080/geoserver/wms?
", {layers: 'unemployment:ue2000_WorldMercator'} )
Shp in WGS84
", {layers: 'unemployment:ue2000_wgs84'} )
I thought that this might work but i does not ... and i do not know
why??
   map = new OpenLayers.Map( 'map', {projection:"EPSG:3395"} );
", {layers: 'unemployment:ue2000_wgs84'} );
", {layers: 'unemployment:ue2000_wgs84'}, { maxExtent: new
OpenLayers.Bounds(33861, 717605, 330846, 1019656), maxResolution:
"auto", projection:"EPSG:3395", units: "m"} );
", {layers: 'unemployment:ue2000_Project_WorldMercator'} );
", {layers: 'unemployment:ue2000_Project_WorldMercator'}, { maxExtent:
new OpenLayers.Bounds(33861, 717605, 330846, 1019656), maxResolution:
Please help me !!!!!
  Kuba
