[OpenLayers-Users] Cluster Layers - Correct placemark format?
Allan Henderson allanhenderson at gmail.com
Mon Nov 24 10:44:40 EST 2008
Hi there,
I'm trying to implement a Cluster layer from a KML feed.  The feed on
it's own is working fine but all falls apart when I try a cluster
strategy.  So I'm thinking this method doesn't work - will clustering
work on a geojson feed instead?  If not - what's the best format to
ensure it all works?  I'm running a GeoDjango system so can switch
format fairly easily.
Thanks,
Allan
