[OpenLayers-Users] maximum ZoomLevel for google maps
Alexandre Dube adube at mapgears.com
Tue Nov 25 08:36:48 EST 2008
Google layers already have fixed resolutions, so using fixed scales will
not help in this case.
Alexandre
S.Reena wrote:
> Hi Rodolfo,
> I am not using google maps as base , I have made my own base layer..but for
> your case playing with the scale would serve the purpose
> I did like this ,
>   map = new OpenLayers.Map('map',{ scales:
> [5000000,2000000,1000000,500000,200000,100000,50000,20000,10000,5000,2000,1000],numZoomLevels:
> 12, maxResolution: "auto",projection: "EPSG:4326", controls: [] });
> Reena
> Rodolfo Moreno wrote:
>> Hi all,
>> I am using openlayers for showing my mapguide layers and google maps as
>> base
>> layer.
>> my problem is that the "zoom in" this limited until a certain scale. In my
>> case the maximum scale that I can achieve is 1:18k (this is what the map
>> shows).
>> I did a comparison with the own google maps GUI (http://maps.google.com/)
>> and I have seen that to my sample application lack it 4 zoom levels in
>> order
>> to achieve the maximum scale.
>> So I was reviewing the openlayers documentation and I found this
>> link(http://trac.openlayers.org/wiki/SettingZoomLevels).
>> I did some change in my code like this:
>> var satellite = new OpenLayers.Layer.Google(
>>                 "Google Satellite" , {type: G_NORMAL_MAP},  {
>> minZoomLevel:
>> 0, maxZoomLevel: 30}
>> but even it doesn't work as I want.
>> I appreciate all idea
>> Regards
>> Rodolfo Moreno
>> CivilEng
>> View this message in context:
>> http://n2.nabble.com/maximum-ZoomLevel-for-google-maps-tp1574304p1574304.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
