[OpenLayers-Users] how select the right feature between 2 superimposed ?
Indika Tantrigoda indika85 at gmail.com
Thu Nov 27 00:24:51 EST 2008
Thanks for the info Eric.
I'll follow up on activating/deactivating the select feature control.
Maybe it would increase the performance of the application since the
controls are created only once.
Indika
2008/11/26 Eric Lemoine <eric.c2c at gmail.com>
> Indika
> So you just let the user choose what layer feature selection works for,
> right?
> I don't know about Sebastien's case but in lots of situations this
> isn't acceptable - it's a pain for the user to select the type of
> objects he's going to query.
> On an unrelated note, I notice that you create a new control each time
> the user switches layer type, instead you could probably have two
> select feature controls and activate/deactivate them based on the
> selected radio button.
> Eric
> 2008/11/26, Indika Tantrigoda <indika85 at gmail.com>:
> > Hi,
> > After looking at
> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/styles_unique_with_group_wfs.htmlI
> > managed to find a
> > work around . I have two wfs point layers, and can activate the
> > selectFeature for the currently selected layer via a radio button.
> > Some of my features were superimposed on top of other layers. However
> when
> > the needed layer is selected via the radio buttons the selected layer is
> > superimposed.
> > Heres my code
> > //inside init()
> > var myHTML = "<input type=radio name=myRadio
> > onclick=test(2)><label>Cities</label> <img src='./img/marker-blue.png'>
> > <br>" myHTML += "<input type=radio name=myRadio
> > onclick=test(3)><label>Stations</label> <img
> src='./img/marker-gold.png'>"
> >             document.getElementById("controls").innerHTML = myHTML;
> > //outside init()
> >      var myLayer;  //global variable
> >      var myObj;     //global variable
> >      function test(id) {
> >             myLayer =id;
> >             if(selectControl)
> >                     //alert("Hiiiiiiiiiiiii");
> >                     selectControl.destroy();
> >              selectControl = new
> > OpenLayers.Control.SelectFeature(map.layers[id],
> > onSelect : onFeatureSelect,
> > onUnselect: onFeatureUnselect
> >             map.addControl(selectControl);
> >             selectControl.activate();
> >             //I didnt think this it necessary to unregister because the
> > control is destroyed above
> >             //map.layers[id].events.unregister('featureselected',
> > map.layers[id], regFeatureSelected);
> >             //map.layers[id].events.unregister('featureunselected',
> > map.layers[id], regFeatureUnselected);
> >            function onFeatureSelect()
> >                var currentLayer = map.layers[myLayer];
> >                var obj = currentLayer.selectedFeatures[0];
> >                myObj = obj
> >                //alert(obj.attributes['name']);
> >                popup = new OpenLayers.Popup.FramedCloud("chicken",
> > obj.geometry.getBounds().getCenterLonLat(),
> >                                      null,
> >                                      "<div style='font-size:.8em'>" +
> > obj.attributes['name'] +"<br />" + "</div>",
> >                                      null, true, onPopupClose);
> >                obj.popup = popup;
> >                map.addPopup(popup);
> >            function onPopupClose(evt) {
> >                      selectControl.unselect(myObj);
> >            function onFeatureUnselect()
> >                //alert("from regFeatureUnselected");
> >               map.removePopup(myObj.popup);
> >               myObj.popup.destroy();
> >               myObj.popup = null;
> > Hope this was helpful.
> > Indika
> >> On Wed, Nov 26, 2008 at 10:20 AM, Sébastien Geindre
> >> <sebastien.geindre at meteo.fr> wrote:
> >> > Eric Lemoine a écrit :
> >> >> Seb, I don't understand your question. If you're trying to get the
> >> >> select feature control to work with multiple layers then you must
> know
> >> >> that that isn't currently supported by OpenLayers. Sorry for not
> >> >> understanding your question. Eric
> >> > you guessed it !
> >> > is there any workaround ?
> >> > all features must be on the same layer ?
> >> Yes.
> >> Eric
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081127/320f529c/attachment.html
