[OpenLayers-Users] re freshing just one layer
Jerome Freyre jerome.freyre at hispeed.ch
Thu Nov 27 04:43:26 EST 2008
Hi Dave,
I think that should be a good idea to create a new post for your question...
For your problem, you can use the http protocol to reload a layer without
reload all your page.
Look at this example to implement the protocol solution :
http://dev.openlayers.org/sandbox/topp/almanac/examples/v2-fixed-http-gml.html
And to reload data, here is a part of solution :
myprotocol = new OpenLayers.Protocol.HTTP({
                            format: new OpenLayers.Format.GeoJSON(),
                            url: "getGeoJSON.php",
                            params: {
                                idView: clickedId
                resp = myprotocol.read({
                    callback: function(resp) {
                        if (!resp.success()) {
                            alert("failure");
                        parser = new OpenLayers.Format.GeoJSON();
                        var featuresResponse =
resp.priv['_object'].responseText;
                        var features = parser.read(featuresResponse);
                        //some code
Dave Potts-2 wrote:
> hi list
> I have a openlayers application that has content loaded from google maps
> and several different layers  supply as gml from a servlet.
> Downloading google maps can take its time.
> If I just want to resresh one of my gml/servlet layers is there any way
> off doing a refresh layer that does'nt require the base google map to be
> reloaded?
> Dave.
> Any views expressed in this message are those of the individual sender,
> except where the sender specifically states them to be the views of the
> Pinan Software
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/about-thematic-maps-tp20706092p20716149.html
