[OpenLayers-Users] WFS polygon or point and Popup
arno974 arnaud.sig at gmail.com
Fri Nov 28 01:41:20 EST 2008
Hi all,
I finally succed, i've solve my problem by making my own object. I extended
the Control Class and had a new control call tooltips.
Here is the new class :
 * 	Purpose: extends OpenLayers API (toolTips)
 * 		Add New Control ToolTips
 *  Author:  Van De Casteele Arnaud
 *	Date:   february 2008
 *	Version: 0.1
 * @requires OpenLayers/Control.js
 * Class: OpenLayers.Control.MousePosition
 * Inherits from:
 *  - <OpenLayers.Control>
OpenLayers.Control.ToolTips = OpenLayers.Class(OpenLayers.Control, {
     * Property: element
     * {DOMElement} The DOM element that contains the toolTips Element
    element: null,
     * Property: text color
	  * Can be a text as black or hexadecimal color as #000000
     * {String}
    textColor: "black",
     * Property: bold text
     * {String}
		bold : false,
     * Property: Opacity
     * {String}
		opacity : 100,
     * Property: background color
	  * Can be a text as white or hexadecimal color as #FFFFFF
     * {String}
    bgColor: "white",
     * Property: Padding of the div
     * {String}
    paddingValue : "2px",
     * Property: lastXy
     * {<OpenLayers.LonLat>}
    lastXy: null,
		html : null,
     * Constructor: OpenLayers.Control.MousePosition
     * Parameters:
     * options - {DOMElement} Options for control.
    initialize: function(options) {
		  //Extend with new arguments
		  	var newArguments = [];
        OpenLayers.Util.extend(this, options);
        OpenLayers.Control.prototype.initialize.apply(this, arguments);
     * Method: destroy
     destroy: function() {
         if (this.map) {
             this.map.events.unregister('mousemove', this, this.redraw);
         OpenLayers.Control.prototype.destroy.apply(this, arguments);
     * Method: draw
		 * Used with the mapadd.Control
     * {DOMElement}
    draw: function() {
				OpenLayers.Control.prototype.draw.apply(this, arguments);
				// Create the Div in the DOM
				// Div background
				this.divBgTtips = document.createElement("div");
						this.divBgTtips.id = OpenLayers.Util.createUniqueID("divBgTtips");
						this.divBgTtips.className = this.displayClass + 'ToolTipsElement';
						this.divBgTtips.style.backgroundColor = this.bgColor;
						this.divBgTtips.style.display = "none";
						this.divBgTtips.style.position = "absolute";
						this.divBgTtips.style.zIndex = "100000";
						this.divBgTtips.style.padding = "2px 5px 2px 5px";
						this.divBgTtipsTx = document.createElement("span");
						if(this.bold){this.divBgTtipsTx.style.fontWeight="bold";}
						this.divBgTtips.appendChild(this.divBgTtipsTx);
						//BG Opacity
						this.divBgTtips.style.filter="alpha(opacity="+this.opacity*100+")";
						this.divBgTtips.style.opacity=this.opacity;
//document.getElementById(this.map.div.id).appendChild(this.divBgTtips);
						document.body.appendChild(this.divBgTtips);
				// Div for the text
				// Hack to have a transparent background and a 100 opacity text
				this.divTxTtips = document.createElement("div");
						this.divTxTtips.id = OpenLayers.Util.createUniqueID("divTxTtips");
						this.divTxTtips.style.color = this.textColor;
						this.divTxTtips.style.display = "none";
						this.divTxTtips.style.position = "absolute";
						this.divTxTtips.style.zIndex = "100001";
						this.divTxTtips.style.padding = "2px 5px 2px 5px";
						if(this.bold){this.divTxTtips.style.fontWeight="bold";}
				document.getElementById(this.map.div.id).appendChild(this.divTxTtips);
				//this.divTxTtips = this.clone(this.divBgTtips);
				document.body.appendChild(this.divTxTtips);
				this.map.events.register('mousemove', this, this.redraw);
     * Method: show
		 * Show the tooltips on the map
		show : function(valueHTML){
			this.divBgTtipsTx.innerHTML = valueHTML.html;
			this.divBgTtipsTx.style.visibility = "hidden";
			this.divTxTtips.innerHTML = valueHTML.html;
			this.divTxTtips.style.display = "block";
			this.divBgTtips.style.display = "block";
     * Method: hide
		 * hide the tooltips on the map
		hide : function(){
     * Method: findXYmap
		 * To Know the position of the map in the HTML
		findXYMap : function(obj){
			 var x=0,y=0;
			 while (obj!=null){
			 x+=obj.offsetLeft-obj.scrollLeft;
			 y+=obj.offsetTop-obj.scrollTop;
			 obj=obj.offsetParent;
			 return {x:x,y:y};
     * Method: redraw the div
		 * with new position params
    redraw: function(evt) {
			marginPos = this.findXYMap(document.getElementById(this.map.div.id));
			this.divBgTtips.style.left = ((evt.xy.x+marginPos.x)+22)+"px";
			this.divBgTtips.style.top = ((evt.xy.y+marginPos.y)-12)+"px";
			this.divTxTtips.style.left = ((evt.xy.x+marginPos.x)+22)+"px";
			this.divTxTtips.style.top = ((evt.xy.y+marginPos.y)-12)+"px";
    CLASS_NAME: "OpenLayers.Control.ToolTips"
And an HTML example :
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
        <head>
        <title>OpenLayers ToolTips</title>
<style type="text/css">
	body {
		margin : 20px;
	#map {
		width: 800px;
		height: 626px;
		border: 1px solid black;
</style>
<script src="../lib/js/OpenLayers/OpenLayers.js"
type="text/javascript"></script>
<script src="../lib/js/OpenLayers/lib/OpenLayers/Control/TooltTips.js"
<script defer="defer" type="text/javascript">
 function init(){
      var bounds = new OpenLayers.Bounds(
          55.185611724, -21.415085482499997,
          55.867049316, -20.8459795275
      var options = {
          controls: [],
          maxExtent: bounds,
          maxResolution: 0.002661865593750007,
          projection: "EPSG:4326",
          units: 'degrees'
      map = new OpenLayers.Map('map', options);
     var wms = new OpenLayers.Layer.WMS("OpenLayers WMS",
       "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'}, {buffer:
0});
			var markers = new OpenLayers.Layer.Markers("Marker");
			markers.addMarker(new OpenLayers.Marker(new
OpenLayers.LonLat(55.48,-20.96)));
			markers.events.register("mouseover", markers, toolTipsOver);
			markers.events.register("mouseout", markers, toolTipsOut);
			map.addLayers([wms,markers]);
			ttips = new OpenLayers.Control.ToolTips({bgColor:"red",textColor
:"black", bold : true, opacity : 0.50});
			map.addControl(ttips);
			map.addControl(new OpenLayers.Control.PanZoomBar());
      map.addControl(new OpenLayers.Control.Navigation());
			map.addControl(new OpenLayers.Control.MousePosition());
			map.addControl(new OpenLayers.Control.LayerSwitcher());
			map.zoomToExtent(bounds);
			function toolTipsOver(e) {
				ttips.show({html:"My first ToolTips"});
			function toolTipsOut(e){
				ttips.hide();
</script>
</head>
	<body onload="init()">
      <div id="map"></div>
  </body>
</html>
If you see something to improve tell me.
Best regards
Arnaud
arno974 wrote:
> Hi all,
> I've been working for two day in a way to display some popup or labels
> when i'm on hover of a feature WFS object. I've googled and search on this
> list but i couldn't find any solutions.
> Maybe you know a "simple" solution to add an hover events on a WFS layer
> and in this events i must know my mouse position to display the popup.
> I've tried to do it like that :
> sf = new OpenLayers.Control.SelectFeature(wfs, {hover : true , onSelect :
> __toolTips})
> It works fine for the onHover event but i can't handler my mouse position
> to display the bubble.
> Thnaks for any help.
> Arnaud
View this message in context: http://www.nabble.com/WFS-polygon-or-point-and-Popup-tp20695049p20729651.html
