[OpenLayers-Users] open popup in open layers from external list
Leo leonardo.burchi at megalab.it
Sun Oct 5 08:57:22 EDT 2008
Hi to all, I have a map with a lot of marker. Every marker is added by the
function at the bottom. All works very well and i can see all marker in the
map with its popup if i click on it. Now I would create a popup window with
an html list of all markers in the map and if i click an item i want the
marker associated in the map opens its popup.
I've looked in the example, but i can't find the solution. Is there a way to
do what i need?
Thank you very much for your help!
function addMarker(ll, popupClass, popupContentHTML, closeBox, overflow,
iconID) {
				var size = "";
				var offset = "";
				var icon = "";
				switch (iconID)
					case 1:
						size = new OpenLayers.Size(17,29);
	    		        offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
						icon = new
OpenLayers.Icon(\'./templates/images/GREEN.png\',size,offset);
					}break;
					case 2:
						size = new OpenLayers.Size(8,8);
						icon = new
OpenLayers.Icon(\'./templates/images/listitem.png\',size,offset);
					}break;
					case 3:
						icon = new
OpenLayers.Icon(\'./templates/images/RED.png\',size,offset);
					}break;
					default:
						icon = new
OpenLayers.Icon(\'./templates/images/AQUA.png\',size,offset);
					}break;
				var feature = new OpenLayers.Feature(markers, ll, {icon: icon});
            	feature.closeBox = closeBox;
	            feature.popupClass = popupClass;
	            feature.data.popupContentHTML = popupContentHTML;
	            feature.data.overflow = (overflow) ? "auto" : "hidden";
    	        var marker = feature.createMarker();
        	    var markerClick = function (evt) {
            	    if (this.popup == null) {
                	    this.popup = this.createPopup(this.closeBox);
                   	 	map.addPopup(this.popup);
                   		this.popup.show();
                	} else {
                    	this.popup.toggle();
    		         currentPopup = this.popup;
            	    OpenLayers.Event.stop(evt);
	            marker.events.register("mousedown", feature, markerClick);
    	        markers.addMarker(marker);
View this message in context: http://n2.nabble.com/open-popup-in-open-layers-from-external-list-tp1298733p1298733.html
