[OpenLayers-Users] OpenLayers.Request.POST/GET errors
Heidt, Christopher M.
CHRISTOPHER.M.HEIDT at saic.com
Tue Oct 7 17:55:52 EDT 2008
params are added to the get string and data is added to post data, both
need to be objects.
have you tried:
new OpenLayers.Request.issue({
method: 'POST',
url:'http://www.host.com/lib/printMap.php
<http://www.host.com/lib/printMap.php> ',
params: {
getStringItem1:'cheesburger',
item2:'wambat'
data:{
postedUsername: 'myUsername',
postedPassword: 'myPassword'
success: function(request){
alert(request.responseText);
failure:function(request){
alert('BOOOOOO!');
and have you checked the $_GET and $_POST arrays in PHP? the request
array is usually frowned upon.
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Ian
Sent: Tuesday, October 07, 2008 4:53 PM
To: users at openlayers.org
Subject: [OpenLayers-Users] OpenLayers.Request.POST/GET errors
I am working on the Printing code from the wiki using the new ver. 2.7
OpenLayers.Request.POST/GET. The problem is that data is not appearing
in PHP's @$_REQUEST array. For example:
var printURL = 'http://www.host.com/lib/printMap.php';
var size = map.getSize();
var postParams = 'width=' + size.w + '&height=' + size.h;
new OpenLayers.Request.POST({url:printURL, data:postParams,
callback:printDone});
results in an empty REQUEST array. Firebug says width=500&height=500 is
posted. Same for GET:
var getParams = {width: size.w, height: size.h};
new OpenLayers.Request.GET({url:printURL, params:getParams,
Submitting parameters directly (eg.
http://www.host.com/lib/printMap.php?width=500&height=400) does place
the values in the REQUEST array. I'm following the examples at
http://trac.openlayers.org/wiki/Request and using Apache 2/PHP
5.2.6/Firefox 3.03. Am I missing something?
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081007/8d1085ca/attachment.html
