[OpenLayers-Users] OpenLayers.DOTS_PER_INCH as global setting seems shouldn't be changed just for only mapguide layer while other layers added together
Paul Spencer pagameba at gmail.com
Wed Oct 8 09:15:58 EDT 2008
Hi Carl,
I think this should only be done if MapGuide is the base layer, if it
is used as an overlay then the DPI probably shouldn't be changed.  I
think it would be useful to be able to specify per-layer DPI values
and have added a ticket (http://trac.openlayers.org/ticket/1768) to
OpenLayers trac to open up a discussion on this.  The implementation
should not be difficult but there may be implications that I am not
aware of.
Cheers
Paul
On 7-Oct-08, at 11:57 AM, Carl wrote:
> From Openlayers document, it can be found:
> MapGuide OS uses a DPI value and degrees to meters conversion
> factor that are different than the defaults used in OpenLayers, so
> these
> must be adjusted accordingly in  your application.  See the MapGuide
> example
> for how to set these values for MGOS.
> From mapguide.html, it can be found:
>       var metersPerUnit = 111319.4908;  //value returned from mapguide
>        var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
>        OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
>        OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
>        OpenLayers.DOTS_PER_INCH = 96;
> it seems both OpenLayers.INCHES_PER_UNIT and
> OpenLayers.DOTS_PER_INCH are
> global settings.
> I doubt if two different layers, such as WMS and MapGuide are added to
> Openlayers Map, the above settings will influence both layers. but
> it seems
> the settings shouldn't be changed for WMS?
> View this message in context: http://www.nabble.com/OpenLayers.DOTS_PER_INCH-as-global-setting-seems-shouldn%27t-be-changed-just-for-only-mapguide-layer-while-other-layers-added-together-tp19861382p19861382.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
