[OpenLayers-Users] Any idea of using setUrl on GeoRSS layer?
Arnd Wippermann
arnd.wippermann at web.de
Wed Oct 8 14:55:13 EDT 2008
setUrl is likely meant to get an url to an georss-file and not to interprete
an returned georss-string.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Deli Soetiawan
Gesendet: Mittwoch, 8. Oktober 2008 08:42
An: users at openlayers.org
Betreff: [OpenLayers-Users] Any idea of using setUrl on GeoRSS layer?
Hi there,
i tried to create a georss layer that can do auto-refresh after specified
time, here the code for layer:
var iconMarker = new OpenLayers.Icon("images/markerblue.png", new
OpenLayers.Size(16,16)); var rssLayer = new
OpenLayers.Layer.GeoRSS('GeoRSS','georss.php',{icon:iconMarker});
map.addLayer(rssLayer);
here the code for refreshing georss layer:
setInterval(reloadRSS,60000); //reload every 60 seconds function reloadRSS()
rssLayer.setUrl('georss.php');
the georss.php generate dynamic georss from database (not really important
what the content is) according to:
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Layer/Ima
ge.js
setUrl function was defined, the parameter for this function is url of the
georss, so it can be use to reload the xml (formerly in Kamap application
i've made i use this kind of function) but it can't work?
when i debug using JS debugger (in Opera 9.6 Final):
Timeout thread: delay 60000 ms
Error:
message: Statement on line 41: Type mismatch (usually non-object value
supplied where object required)
the line 41 is referencing to "rssLayer.setUrl('georss.php');" code, so why
type mismatch? do i set invalid type for parameter? is it correct to use
string ("georss.php") as parameter?
or any other way to refresh this layer type? (if you can please share some
working example :D)
Thanks,
Deli Soetiawan
View this message in context:
http://www.nabble.com/Any-idea-of-using-setUrl-on-GeoRSS-layer--tp19873179p1
9873179.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
