[OpenLayers-Users] Transparency for WMS layers cached with GeoWebcache
bartvde at osgis.nl bartvde at osgis.nl
Thu Oct 9 11:03:39 EDT 2008
Jpeg does not have transparency, so change your format to something else.
Best regards,
Bart
> Good afternoon,
> I am trying to setup some transparency for a layer which is cached by GWC.
> This is my code:
> var options = { maxExtent: new OpenLayers.Bounds(-180,-90,180,90),
>                                         units: 'degrees',
>                                         projection: "EPSG:4326",
>                                         maxResolution: 0.703125
> var map = new OpenLayers.Map('map',options);
> var wms = new OpenLayers.Layer.WMS("All Areas","/figis/geoserver/wms?",
> {layers:'fifao:FAO_DIV',
>        format:
> 'image/jpeg'},{buffer: 0, isBaseLayer: true, wrapDateLine: true,
> singleTile:
> true});
> var wms3 = new
> OpenLayers.Layer.WMS("Countries","/figis/geoserver/gwc/service/wms?service=wms",
> {layers:'fifao:UN_CONTINENT',
> transparent:true,
>        format:
> 'image/jpeg'},{buffer: 0,opacity: 0.85,isBaseLayer: false, wrapDateLine:
> true});
> var wms_continent_background = new
> OpenLayers.Layer.WMS("Background","/figis/geoserver/wms?service=wms",
>        {layers:
> 'fifao:ISO3_COUNTRY',
> format:'image/jpeg',
> transparent:true,
> "cql_filter":"ISO_3='EUR'"},{buffer: 0, wrapDateLine: true, isBaseLayer:
> false, singleTile: true});
> map.addLayer(wms);
> map.addLayer(wms3);
> map.addLayer(wms_continent_background);
> map.zoomToMaxExtent();
> In that configuration, FAO_DIV and ISO3_COUNTRY are the only layers to be
> displayed.
> When i remove the transparency option for the UN_CONTINENT layer, the map
> is
> correctly generated but FAO_DIV which is my base layer can only be seen
> partially:
> http://www.nabble.com/file/p19900780/Untitled-2opy.jpg
> I really need to have this UN_CONTINENT to be transparent. I know it can
> be
> done.
> Could someone tell me how to put this layer which is cached by GWC as
> transparent in my configuration?
> Thanks a lot in advance
> Sylvain
> OL 2.6
> Geoserver+GWC:1.7-RC3
> Oracle Locator DB
> http://www.nabble.com/Transparency-for-WMS-layers-cached-with-GeoWebcache-tp19900780p19900780.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
