[OpenLayers-Users] Can't get VE map to work
Lennox Antoine lxnyce at gmail.com
Thu Oct 9 12:19:14 EDT 2008
Hey Chris,
Thanks for checking it out. I looked at the map in Firebug, and see no
error. I do have a consistent way to reproduce though. Make sure your
browser is not maximized. Pan the Google Map that comes up. Switch to
Virtual Earth, and pan around, that should still work. Resize your browser,
then try to pan that Virtual Earth map again. It goes bonkers for me. I have
tested in Firefox, Chrome.
Lennox
On Thu, Oct 9, 2008 at 11:57 AM, chaak <haak at agintegrated.com> wrote:
> Hi Lennox,
> I don't know if you've found your error yet, but maybe I can help a little.
> I fought with a weird error with the panning as well.  I only had a problem
> when using Virtual Earth; probably similar to what you were having, but I
> didn't see it on the site that you posted.  I tracked my error down to
> being
> a conflict with the Virtual Earth variables that they use in their JS file.
> MicroSoft obstruficates their code, so everything runs off of variables
> like
> a, b, c, etc...  After a few days of searching through my code, I found I
> had one "g" variable set globally, which conflicted with the VE g function.
> Look in your error console and see if there is an error based on a letter.
> If so, chances are that you're experiencing what I did.
> Chris
> Lennox Antoine wrote:
> > I've noticed a resize issue. Don't know if it's new or not though. Take a
> > look at this map :
> http://vizuresoft.com/mapstudio/clients/D5D90F37AACB3ACEB42192770369E577/map10/fullscreen.html
> > Don't mind the cartesian overlay over the mercator map.
> > It starts out with Google Maps. Switch to Virtual Earth. Notice that if
> > you
> > try to pan now, it doesn't pan correctly. It only seems to occur with the
> > Virtual Earth map. Switch to any of the other basemaps, and it doesn't
> > behave this way.
> > Lennox
> http://n2.nabble.com/Can%27t-get-VE-map-to-work-tp1088773p1312656.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081009/ac1f456a/attachment.html
