[OpenLayers-Users] delete feature & vertices - further
Eric Lemoine eric.c2c at gmail.com
Thu Oct 16 00:48:43 EDT 2008
Hi. Do you also have a modify feature control? The select feature and
modify feature controls are known not to play well together. There
already is a ticket about that, and patch attached to it. Eric
2008/10/16, Robert Sanson <SansonR at asurequality.com>:
> I have tried destroyFeatures, removeFeatures and eraseFeatures and they all
> seem to have the same behaviour. The polygon disappears but the vertices
> remain.
> var delf =  new OpenLayers.Control.SelectFeature(crops, {onSelect:
> function(feature) {crops.destroyFeatures([feature])}});
> map.addControl(delf);
> delf.activate();
> Robert Sanson
>>>> Tim Schaub <tschaub at opengeo.org> 5/08/2008 12:13 a.m. >>>
> Hey-
> Adorian Ardelean wrote:
>> Hi,
>> After upgrading to OL 2.6, delete feature function does not work
>> correctly:
>> when a polygon or polyline is removed, the lines that define the
>> disappear, but the vertexes not (the vertexes appear as the entity is
>> selected). The code worked flawlessly in previous version. Is something
>> that I have to be aware and/or modify?
>> declaration of control
>> deletefeature: new
>> OpenLayers.Control.SelectFeature(vectors,{onSelect:deleteFeature})
>> delete function
>> function deleteFeature(geometry)
>>   this.layer.removeFeatures(geometry);
>> Any hint that may solve this issue is appreciated,
> I just tried the following and confirmed that the above works.
> 1) open http://openlayers.org/dev/examples/draw-feature.html
> 2) draw a polygon (note freehand is true here)
> 3) in the firebug console, run this code:
> var del = new OpenLayers.Control.SelectFeature(
>      map.layers[3], {
>          onSelect: function(feature) {
>              map.layers[3].removeFeatures([feature]);
> map.addControl(del);
> del.activate();
> 4) click on your polygon to see it removed
> I suspect you really want to be calling destroyFeatures instead of
> removeFeatures - unless you call feature.destroy elsewhere.
> Tim
>> Adorian
>> Dr. Adorian Ardelean
>> coordinator of myNature Project
>> proiectul myNature
>> str. Rascoala din 1907 nr 12
>> Timisoara 300523
>> Romania
>> http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> biodiversity-database]
>> http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
> The contents of this email are confidential to AsureQuality. If you have
> received this communication in error please notify the sender immediately
> and delete the message and any attachments. The opinions expressed in this
> email are not necessarily those of AsureQuality. This message has been
> scanned for known viruses before delivery. AsureQuality supports the
> Unsolicited Electronic Messages Act 2007. If you do not wish to receive
> similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
