[OpenLayers-Users] MapServer OpenLayers Layer fails to load
jeffcopes jcopes at harris.com
Thu Oct 16 10:47:12 EDT 2008
Here are the layers:
  # City layer - Cities
  LAYER
     NAME "cities"
     GROUP "CITIES"
     DATA "/ssa/data/MapServer/Earth/Vectordata/WorldMap/Cities"
     STATUS off
     PROCESSING "CLOSE_CONNECTION=DEFER"
     TYPE point
     LABELCACHE on
     MAXSCALE 290
     LABELMAXSCALE 150
     CLASS
        NAME "Cities"
        EXPRESSION(3 <= [POP_RANK] and [POP_RANK] <= 5)
        STYLE
           SYMBOL "Circle"
           SIZE 4
           COLOR 255 255 0
        END
        TEXT ([CITY_NAME])
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arialbd"
           SIZE 7
           POSITION auto
           OUTLINECOLOR 255 255 255
           COLOR 0 0 0
        END
     END
  END
  # Cities layer - Large cities, pop. < 1,000,000
  LAYER
     NAME "largecities"
     GROUP "CITIES"
     STATUS off
     TYPE point
     LABELCACHE on
     MAXSCALE 290
     LABELMAXSCALE 150
     CLASS
        EXPRESSION([POP_RANK]<=2)
        NAME "Cities"
        STYLE
           SYMBOL "Circle"
           SIZE 6
           COLOR 255 0 0
           BACKGROUNDCOLOR 255 0 0
        END
        TEXT ([CITY_NAME])
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arialbd"
           SIZE 8
           POSITION auto
           COLOR 0 0 0
        END
     END
  END
  # Cities layer - State capitals and cities pop. > 1000000
  LAYER
     NAME "majorcities"
     GROUP "CITIES"
     STATUS off
     TYPE point
     LABELITEM "NAME"
     LABELCACHE on
     LABELMAXSCALE 15000000
     # NOTE: CLASSITEM causes total map failure (pink map)
     # CLASSITEM "FEATURE"
#      MINSCALE 2000000
     CLASS
        NAME "State Capitals"
        EXPRESSION /State*/
        STYLE
           SYMBOL "Circle"
           SIZE 6
           COLOR 0 255 0
        END
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arialbd"
           SIZE 9
           POSITION auto
           COLOR 0 0 0
        END
     END
     CLASS
        EXPRESSION ([Pop_2000] > 1000000)
        NAME "Major Cities"
        STYLE
           SYMBOL "Circle"
           SIZE 10
           COLOR 255 0 0
        END
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arialbd"
           SIZE 10
           COLOR 0 0 0
           POSITION auto
        END
     END
  END
  # City layer - Towns
  LAYER
     NAME "towns"
     GROUP "CITIES"
     STATUS off
     TYPE point
     LABELCACHE on
     LABELITEM "NAME"
     LABELMAXSCALE 20
     MAXSCALE 4
     CLASS
        NAME "Towns"
        EXPRESSION ([Pop_2000] < 5000)
        STYLE
           SYMBOL "Circle"
           SIZE 4
           COLOR 0 255 0
        END
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arialbd"
           SIZE 7
           POSITION auto
           COLOR 0 0 0
        END
     END
  END
############# START BLUE MARBLE WORLD LAYER ######################
 LAYER
  # name of layer
  # sets:
  # /WMT_MS_Capabilities/Capability/Layer/*/Name
  # /WFS_Capabilities/FeatureTypeList/FeatureType[*]/Name
  NAME "blue_marble_world"
  # group layer belongs to
  # this is used to add an extra <Layer> nest
  # to the output Capabilities XML
  GROUP "IMAGERY"
  # projection: if the data is NOT in the same projection as the global
  # mapfile, you must explicitly give the native projection code of the data
  # Using proj parameters is quicker, bypasses file lookup
# PROJECTION
#  "init=epsg:4326"
# END
 PROJECTION
  "proj=latlong"
  "ellps=WGS84"
  "datum=WGS84"
 END
  # what type of data is this?
  TYPE RASTER
  # allow data access via query and WCS
  DUMP TRUE
  # always returned with interface
  STATUS off
  # Minimum scale that the layer will show (1 = 100K), (2 = 200K)
  MINSCALE 3
  # actual data pointer
  DATA "/ssa/data/MapServer/Earth/imagery/world_mid_res0.tif"
  # Set a PROCESSING directive to tell FastCGI to cache the connections and
layer information
  # on all layers for which connection caching is desired (in other words,
all slow layers)
  # for HTML queries
  HEADER   ../web/templates/world_topo_2048_query_header.html
  TEMPLATE ../web/templates/world_topo_2048_query_body.html
  METADATA
   # OGC:WMS specific tags
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/Title
   "ows_title"    "Land Surface, Shallow Water, and Shaded Topography"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/Abstract
   "ows_abstract"    "Much of the information contained in this image came
from a single remote-sensing device-NASA's Moderate Resolution Imaging
Spectroradiometer, or MODIS. Flying over 700 km above the Earth onboard the
Terra satellite, MODIS provides an integrated tool for observing a variety
of terrestrial, oceanic, and atmospheric features of the Earth. The land and
coastal ocean portions of these images are based on surface observations
collected from June through September 2001 and combined, or composited,
every eight days to compensate for clouds that might block the sensor's view
of the surface on any single day. Two different types of ocean data were
used in these images: shallow water true color data, and global ocean color
(or chlorophyll) data. Topographic shading is based on the GTOPO 30
elevation dataset compiled by the U.S. Geological Survey's EROS Data Center.
MODIS observations of polar sea ice were combined with observations of
Antarctica made by the National Oceanic and Atmospheric Administration's
AVHRR sensor - the Advanced Very High Resolution Radiometer. The cloud image
is a composite of two days of imagery collected in visible light wavelengths
and a third day of thermal infra-red imagery over the poles. Global city
lights, derived from 9 months of observations from the Defense
Meteorological Satellite Program, are superimposed on a darkened land
surface map"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/KeywordList/Keyword[]
   "ows_keywordlist"    "NASA,MODIS,AVHRR,EROS"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/@opaque
   "wms_opaque"    "1"
   # this positions this layer definition within the GROUP defined above
   "wms_group_title" "IMAGERY"
   # this is the abstract text associated with "wms_group_title"
   # you only need to define this once
   "wms_group_abstract" "Imagery layers"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/BoundingBox/@resx
   # full resolution
   "wms_resx" "0.087890625"
   # half resolution
#   "wms_resx" "0.175781250"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/BoundingBox/@resy
   # full resolution
   "wms_resy" "0.087890625"
   # half resolution
#   "wms_resy" "0.175781250"
   # sets:
   # /WMT_MS_Capabilities/Capability/Layer/*/LatLonBoundingBox
   "ows_extent" "-180 -90 180 90"
   # sets
/WMT_MS_Capabilities/Capability/Layer/*/MetadataURL/OnlineResource/@type
   "ows_metadataurl_type" "FGDC"
   # sets /WMT_MS_Capabilities/Capability/Layer/*/MetadataURL/Format
   "wms_metadataurl_format" "text/html"
   # sets
/WMT_MS_Capabilities/Capability/Layer/*/MetadataURL/OnlineResource/@xlink:href
   "ows_metadataurl_href"
"http://earthobservatory.nasa.gov/Newsroom/BlueMarble/"
   # sets /WMT_MS_Capabilities/Capability/Layer/*/DataURL/Format
   "wms_dataurl_format" "image/tiff"
   # sets
/WMT_MS_Capabilities/Capability/Layer/*/DataURL/OnlineResource/@xlink:href
   "wms_dataurl_href"
"http://earthobservatory.nasa.gov/Newsroom/BlueMarble/Images/land_shallow_topo_2048.tif"
   # OGC:WFS specific tags
   # None!  This is raster data, not covered by OGC:WFS
"gml_include_items" "all"
  END
 END
############# END BLUE MARBLE WORLD LAYER######################
  # hydrographic layer - lakes
  LAYER
     NAME "lakes"
     GROUP "HYDRO"
     DATA "/ssa/data/MapServer/Earth/Vectordata/WorldMap/Hydro"
     STATUS off
     TYPE line
     LABELCACHE on
     LABELITEM "NAME"
     MAXSCALE 20
     TRANSPARENCY 50
     CLASS
        EXPRESSION ('[NAME]' eq 'N/A')
        STYLE
           SYMBOL "BigLine"
           SIZE 2
           COLOR 50 110 180
           OUTLINECOLOR 0 0 0
        END
        TEXT (n/a)
        LABEL
           PARTIALS false
           TYPE truetype
           FONT "arial"
           SIZE 7
           OUTLINECOLOR 200 195 190
           COLOR 20 80 140
           MINDISTANCE 300
           POSITION lr
           MINFEATURESIZE auto
        END
     END
  END
  # Hydrographic layer - streams & rivers
  LAYER
     NAME "rivers"
     GROUP "HYDRO"
     DATA "/ssa/data/MapServer/Earth/Vectordata/WorldMap/MajorRivers"
     STATUS off
     TYPE line
     LABELCACHE on
     LABELITEM "NAME"
     TRANSPARENCY 50
     CLASS
         EXPRESSION ('[NAME]' ne 'N/A')
         STYLE
            SYMBOL "BigLine"
            SIZE 2
            COLOR 50 110 180
            OUTLINECOLOR 0 0 0
         END
         LABEL
            PARTIALS false
            TYPE truetype
            FONT "arial"
            SIZE 7
            COLOR 20 80 140
            MINDISTANCE 300
            POSITION lr
            MINFEATURESIZE auto
         END
      END
   END
   # Country Boundaries layer
   LAYER
      NAME "countries"
      GROUP "COUNTRIES"
      DATA
"/ssa/data/MapServer/Earth/Vectordata/WorldMap/CountriesGeneralized"
   PROJECTION
      "proj=latlong"
      "ellps=WGS84"
      "datum=WGS84"
 END
      STATUS off
      TYPE polygon
      LABELCACHE on
      # Don't show the label at this level
      #LABELITEM "NAME"
      # 3:  shows at <=216K
      # 4:  shows at <=433K
      # 5:  shows at <=433K
      # 6:  shows at <=865K
      # 12:  doesn't show at <=2M
      MAXSCALE 600
      #MINSCALE 6
      TRANSPARENCY 30
      CLASS
         NAME "Countries"
     #     STYLE
         SYMBOL "Circle"
           SIZE 3
     #             # yellow: 255 255 0
     #             # pale blue: 255 64 0
     #             COLOR 255 64 0
         OUTLINECOLOR  215 16 0
     #       END
     #        OVERLAYSYMBOL "Circle"
     #        OVERLAYSIZE 3
     #        OVERLAYCOLOR 255 64 0
         TEXT ([CNTRY_NAME])
         LABEL
            PARTIALS false
            TYPE truetype
            FONT "verdana"
            SIZE 9
            OUTLINECOLOR 215 215 215
            COLOR 215 16 0
            MINDISTANCE 600
            POSITION lr
            MINFEATURESIZE 150
         END
      END
   END
View this message in context: http://www.nabble.com/MapServer-OpenLayers-Layer-fails-to-load-tp19982976p20014905.html
