[OpenLayers-Users] Sort of Feature switcher
Arnd Wippermann arnd.wippermann at web.de
Thu Oct 16 18:03:49 EDT 2008
Hi Pascal,
Interesting problem. I have added some functionality to the last example.
Perhaps it helps.
I use a stylemap with addUniqueValueRules for the gml layer with a rule for
attribute visibility.
If the attribute visibility = "visible" the feature is visible.
To change the visibility, I change the attribute of the feature to "hidden"
and redraw the feature.
I'm not sure, if it's the straight way, to change the visibility of
features.
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/select-feature-with
-function.html
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von darrepac
Gesendet: Donnerstag, 16. Oktober 2008 20:48
An: users at openlayers.org
Betreff: [OpenLayers-Users] Sort of Feature switcher
Hello,
Thanks to Arnd, I have implemented a GML layer with some polygons on top of
an other layer (now WMS). Some polygons are one over an other and sometimes,
it is simply not possible to select one polygon as it is behind some others.
For this reason and also to ease the User Experience, I would like to have a
sort of Feature Switcher:
Like the current layer switcher but instead of just viewing/uviewing the
different layer, I would like also to view/unview each feature of my GML
file.
So the user would be able to view only some specific polygon features.
Is there some way to do this?
thanks
View this message in context:
http://www.nabble.com/Sort-of-Feature-switcher-tp20016172p20016172.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
