[OpenLayers-Users] Problem with Protocol HTTP and vector layer
Eric Lemoine eric.c2c at gmail.com
Tue Oct 21 11:14:03 EDT 2008
On Tue, Oct 21, 2008 at 1:41 PM, Jérome Freyre <jerome.freyre at hispeed.ch> wrote:
> Based on the example
> (http://openlayers.org/dev/examples/protocol-gears.html), I create a method
> called sync :
> function sync() {
> 	resp = view.protocol.read();
> 	if (!resp.success()) {
> 		alert("reading failed");
> 	        return;
> 	view.destroyFeatures();
> 	if (!resp.features || resp.features.length <= 0) {
> 		alert("No features to read");
> 	        return;
> 	view.addFeatures(resp.features);
> 	alert("features successfully read");
> view.protocol.read() is correctly working (I saw the call to getGeoJSON in
> firebug) and my getGeoJSON.php return the correct GeoJSON. But my function
> always do the alert on the "reading failed" and I don't understand why!?
Because, as opposed to Protocol.Gears, Protocol.HTTP is asynchronous.
You need to pass a callback to read() and read the response from
there:
protocol.read({
    callback: function(resp) {
            alter("failure");
Eric
