[OpenLayers-Users] Update: Interesting Firebug exception report
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 22 23:27:09 EDT 2008
I am also seeing exactly the same problem, first click error,
subsequent ones work
On Thu, Oct 23, 2008 at 11:26 AM, Greg Ederer <greg at ergonosis.com> wrote:
> Here's line 224 expanded:
> var factory=null;
> if(typeof GearsFactory!='undefined')
>   factory=new GearsFactory();
> else
>   try
>     factory=new ActiveXObject('Gears.Factory');
>     if(factory.getBuildInfo().indexOf('ie_mobile')!=-1)
>       factory.privateSetGlobalObject(this);
>   catch(e)
>     if((typeof
> navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){
>       factory=document.createElement("object");
>       factory.style.display="none";
>       factory.width=0;
>       factory.height=0;
>       factory.type="application/x-googlegears";
>       document.documentElement.appendChild(factory);
> I'm not using Gears.  Not sure what's causing this.
> Greg
> Greg Ederer wrote:
> The exception is traceable to OpenLayers.js (2.7) line 224:
> var factory=null;if(typeof GearsFactory!='undefined'){factory=new
> GearsFactory();}else{try{factory=new
> ActiveXObject('Gears.Factory');if(factory.getBuildInfo().indexOf('ie_mobile')!=-1){factory.privateSetGlobalObject(this);}}catch(e){if((typeof
> navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){factory=document.createElement("object");factory.style.display="none";factory.width=0;factory.height=0;factory.type="application/x-googlegears";document.documentElement.appendChild(factory);}}}
> Any ideas?
> Cheers,
> Greg
> Greg Ederer wrote:
> Huh.  I fixed the URL, and I still get the exception on the first click.
> Greg Ederer wrote:
> I solved this.  Bad wms URL.
> Cheers,
> Greg
> Greg Ederer wrote:
> Hi,
> I got the following exception:
> uncaught exception: [Exception... "Illegal operation on WrappedNative
> prototype object"  nsresult: "0x8057000c
> (NS_ERROR_XPC_BAD_OP_ON_WN_PROTO)"  location: "JS frame ::
> http://localhost:8080/EWX/scripts/OpenLayers-2.7/OpenLayers.js ::
> anonymous :: line 440"  data: no]
> Line 224
> when executing the following code:
> OpenLayers.loadURL(this.map.parentFrame.wmsUrl, params, this,
> this.launchTimeSeries, this.launchTimeSeries);
> I only get the exception the first few times this method is called
> (within an OpenLayers.Control.Click click handler).
> this.launchTimeSeries does get called even when I get the exception.
> Any thoughts?
> Cheers,
> Greg
> | E R G O N O S I S
> | Greg Ederer
> | Lead Developer
> | 360.774.6848
> ________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> | E R G O N O S I S
> | Greg Ederer
> | Lead Developer
> | 360.774.6848
> Users mailing list
> | E R G O N O S I S
> | Greg Ederer
> | Lead Developer
> | 360.774.6848
> Users mailing list
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
