[OpenLayers-Users] Vector feature attribute name
bartvde at osgis.nl bartvde at osgis.nl
Mon Oct 27 10:04:36 EDT 2008
I assume you are using Mapserver?
So why not create alias-es on your WFS?
"gml_res_co_reg_alias" "RES_CO_REG"
Best regards,
Bart
> Hi list,
>   I have a little problem with attribute names for vector features.  In
> my application, I have 2 data sources ( shapefiles and postGIS ) that
> share the exact same kind of data.  The only difference is the attribute
> names, which are respectively in uppercase and lowercase ( ex. :
> RES_CO_REG, res_co_reg )
>   My application must interact in both ways they are written ( or
> preferably, ANY way they are written), so before using an attribute
> name, I use this little function I've written :
> OpenLayers.Feature.Vector.prototype.getAttributeName = function (szName) {
>     szName = szName.toUpperCase();
>     var szAttribute, key;
>   for ( key in this.attributes ) {
>       szAttribute = key.toUpperCase();
>       if (szAttribute == szName)
>           return key;
>   return false;
> This works on feature objects.  I didn't find a way to do it otherwise.
> Like when using the addUniqueValueRules function, I have to do the
> following :
> oRegStyleMap.addUniqueValueRules("default", "RES_CO_REG", aRegColor);
> oRegStyleMap.addUniqueValueRules("default", "res_co_reg", aRegColor);
>   To me, it seems like my solution is a big waste of time ( having to
> loop into each attribute name every time )...  Is there a better way to
> do it ?
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
