[OpenLayers-Users] [SOLVED] Re: mapserver layer with bad rendering
Didrik Pinte lists at dipole-consulting.com
Mon Oct 27 13:28:26 EDT 2008
Hi Arnd, and list,
The tip you suggest did not make it but ... it was very close.
I used a layer defintion with :
                    map: '/var/data/wms.map',
                    transparent: 'false',
                    layers: 'ortho',
                    format: 'png24',
Looking at the real query send to the MapServer, I saw that there was a
map_imagetype that was still in png !
Changing the layer definition using the following definition solved the
problem :
                    layers: 'ortho',
                    format: 'png24',
                    'map_imagetype': 'png24';
Thanks,
Didrik
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20081027/28190dc0/attachment.bin
