[OpenLayers-Users] WFS Layers, Markers, Popups
Eric Lemoine
eric.c2c at gmail.com
Tue Oct 28 03:05:04 EDT 2008
As Arnd said you should use vectors styled with externalgraphic and
the select feature control to be able to select your markers and
display a popup on feature selection. To be notified on feature
selection register a listener on the layer's featureselected event.
featureselected listeners receive an object with a feature property
referencing the selected feature. This is shown in the example Arnd
pointed you to. Eric
2008/10/28, Indika Tantrigoda <indika85 at gmail.com>:
> Thanks for the reply.
> It seems that when I click within the marker, I get different lon, lat
> values.
> Is it necessary to bind the markers to something ?
> Also with the extractAttributes:true, how can I access the attributes of the
> feature ?
> Regards,
> Indika
> 2008/10/27 Arnd Wippermann <arnd.wippermann at web.de>
>> you can use a select control for the wfs layer.
>> http://openlayers.org/dev/examples/select-feature-openpopup.html
>> If you have load the wfs layer with extractAttributes: true, then your wfs
>> data are saved in the attributes of the features.
>> Arnd Wippermann
>> *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
>> *Im Auftrag von *Indika Tantrigoda
>> *Gesendet:* Montag, 27. Oktober 2008 16:17
>> *An:* OpenLayers users mailing list
>> *Betreff:* [OpenLayers-Users] WFS Layers, Markers, Popups
>> Hi,
>> I have a wfs layer that displays points on my map, using markers.
>> I would like to have a popup that displays data regarding the point which
>> would get activated for a click event.
>> I tried the following but, it seems to return all the data regarding the
>> wfs layer, not the single point, irrespective of
>> where I click on the map.
>> wfs_cities.events.register('click', map, function (e) {
>> document.getElementById('nodelist').innerHTML =
>> "Loading...
>> please wait...";
>> var url = map.layers[2].getFullRequestString(
>> REQUEST: "GetFeature",
>> EXCEPTIONS: "application/vnd.ogc.se_xml",
>> BBOX: map.getExtent().toBBOX(),
>> X: e.xy.x,
>> Y: e.xy.y,
>> INFO_FORMAT: 'text/html',
>> QUERY_LAYERS: map.layers[2].params.LAYERS,
>> FEATURE_COUNT: 50,
>> WIDTH: map.size.w,
>> HEIGHT: map.size.h
>> "http://localhost:8080/geoserver/wfs"
>> Any ideas how I can get around this ?
>> Thanks in advance.
>> Regards,
>> Indika
