[OpenLayers-Users] ModifyFeature: Rotate Center Point and Control
Point
carls
carlshe at 163.com
Wed Oct 29 11:45:28 EDT 2008
while using ModifyFeature control on a regular polygon, it can be found the
rotate center is not right the real center of a regular polygon?
additionally, while rotating and modifying a rectangle parallel to the axis,
the control point for rotating might be at the same position of the
right-bottom corner of the rectangle, which confuses the action of rotation
and modifition, i.e. what i really need is to rotate the rectangle, but
really I moved the right-bottom corner of it.
It is not a big problem. But it will be better if imporved.
Thanks!
Regards, Carl SHE
View this message in context: http://n2.nabble.com/ModifyFeature%3A-Rotate-Center-Point-and-Control-Point-tp1394002p1394002.html
