[OpenLayers-Users] Troubles with WFS-T
Tim Schaub
tschaub at opengeo.org
Thu Oct 30 14:03:01 EDT 2008
Hey-
Zdenek Hynek wrote:
> Hi there,
> I'm experiencing difficulties with WFS-T. I'm trying to update geometry
> of a multipoint layer with the commit method. The transaction failes
> with the following error, though:
> WFS Transaction: FAILED
> <?xml version="1.0" encoding="UTF-8"?>
> <wfs:WFS_TransactionResponse version="1.0.0"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://mapserver.geogr.muni.cz/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd">
> <wfs:InsertResult><ogc:FeatureId fid="none"/></wfs:InsertResult>
> <wfs:TransactionResult> <wfs:Status> <wfs:FAILED/> </wfs:Status>
> <wfs:Message>Error performing insert</wfs:Message>
> </wfs:TransactionResult>
> </wfs:WFS_TransactionResponse>
There could be a number of reasons for this. You'll get more detail if
you do the following:
* Add "?strict=true" to your WFS URL. So, if it was "/geoserver/wfs"
before, make it "/geoserver/wfs?strict=true" (yes, even though the
transaction is POSTed).
* Configure the server for verbose exception logging. More details
from GeoServer folks/site on how to do that.
I'm assuming you are using the WFS layer in 2.7 (or the trunk). If you
are able, you could try the new WFS protocol (not yet in trunk).
Repo dir - http://svn.openlayers.org/sandbox/topp/wfs
If you get more information on the exception, write back.
Tim
> The transaction XML my application is generating is as follows:
> <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" version="1.0.0"
> service="WFS"><wfs:Insert><feature
> :test_tomas_mista
> xmlns:feature="http://www.openplans.org/prepr"><feature:the_geom><gml:MultiPoint
> xmlns
> :gml="http://www.opengis.net/gml"><gml:pointMember><gml:Point><gml:coordinates
> decimal="." cs="," ts
> ">16.696817016601564,49.25109252929687</gml:coordinates></gml:Point></gml:pointMember></gml:MultiPoint
> ></feature:the_geom></feature:test_tomas_mista></wfs:Insert></wfs:Transaction>
> Can anybody grip where the problem might be.
> Thanks
> Regards.
> Zdenek
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
