[OpenLayers-Users] Fixed Scales & minScale problem
Alexandre Dube adube at mapgears.com
Thu Sep 4 10:29:04 EDT 2008
Hi everybody ( including myself :) ),
  This e-mail is the conclusion of my little problem.  I just want to
share my solution and at the same time ask what others think about it.
  I wanted to use fixed map scales & minScale & maxScale at the same
time.  Found out that I couldn't, so instead I specified scales: [25000,
10000] ( for example ) directly in the layer options and it worked.
  Now, I didn't want to write every scales to every layers.  What if I
want to change the map scales ?  That would be long to change every
scales in layers...  So I did this (very simple, but useful) :
=============== code start ==============
 * Method: getScales
 * Returns a array of scales
 * Parameters:
 * nFrom -  integer               The index where to start in map.scales
array
 * nTo -    integer               The index where to end in map.scales array
 * Returns:
 * {Array}  An array of scales from the map.scales array
OpenLayers.Map.prototype.getScales = function (nFrom, nTo) {
    var aToReturn = new Array();
    var i=0;
    for(nFrom; nFrom<=nTo; nFrom++)
        aToReturn[i++] = this.scales[nFrom];
    return aToReturn;
        // map
        var oMapOptions = {
            controls: [], units: 'm', maxResolution: 156543.0339,
            maxExtent: new OpenLayers.Bounds( -1192709.604, -204908.6926,
                                              1172293.7082, 2338511.3665),
            projection: new OpenLayers.Projection("EPSG:32198"),
            numZoomLevels: 11,
            scales: [13000000, 8000000, 4000000, 2000000, 1000000,
                      500000, 250000, 100000, 50000, 25000, 10000]
        oMap = new OpenLayers.Map( 'map', oMapOptions );
        // wfs layer
        olWFSReg = new OpenLayers.Layer.WFS( // 1M, 500K, 250K
            "Régions admin. - WFS", sMSURL,
            { typename: "BDGA_REGIO_S_POLY_1M", map: sBDGAMapPath },
            { extractAttributes: true, typename: "BDGA_REGIO_S_POLY_1M",
              styleMap: oRegStyleMap, scales: oMap.getScales(4,6) });
=============== code end ==============
That's all, folks !
Alexandre
Alexandre Dube wrote:
> Ok, I tried this and it worked :
>         olWFSRoads = new OpenLayers.Layer.WFS(
>             "Routes - WFS", sMSURL,
>             { typename: "BDGA_ROUTE_L_ARC", map: sBDGAMapPath },
>               numZoomLevels: 2, scales: [25000, 10000],      //
>               //minScale: 25000,
>               typename: "BDGA_ROUTE_L_ARC", styleMap: oStyleMap
> Is this a good workaround ?
>> I saw this in Layer.js at line 690 ( OL 2.6 )
>> // Do not use the scales/resolutions at the map level if
>> // minScale/minResolution and maxScale/maxResolution are
>> // specified at the layer level
>> Ok ?  But I want to use both.  I don't understand why we can't set a
>> minScale to a layer at the same time we specify our own scale ranges.  I
>> mean, I work for some of my layers and other not...  I'm confused !
>> Is there a way around ?
>> Alexandre
>>> Hi everybody,
>>>   I've got a strange behavior in my OL application.  I've got some
>>> layers with simple params like minScale/maxScale like the following :
>>> // layer
>>>             { extractAttributes: true, minScale: 25000,
>>>   I use the following map options :
>>> // old way
>>>         var oMapOptions = {
>>>             controls: [],
>>>             units: 'm',
>>>                 -1192709.604,
>>>                 -204908.6926,
>>>                 1172293.7082,
>>>                 2338511.3665
>>>   I want to use more rounded scale numbers, like the following :
>>> // new way
>>>         var oMapOptions = {
>>>             controls: [],
>>>             units: 'm',
>>>                 -1192709.604,
>>>                 -204908.6926,
>>>                 1172293.7082,
>>>                 2338511.3665),
>>>             numZoomLevels: 11,
>>> 1000000,                   // <---------------
>>> The problem is, some of my layer loses their minScale value ( like the
>>> one above, olWFSRoads ).  It's changed to 13000000 as soon as it's added
>>> to the map !  I have an other WMS layer that does the same thing, and
>>> some others don't...  But they have the same params.
>>> Is this a bug or I'm missing something new when I set scales : [...] as
>>> a new map option ?
Alexandre Dubé
Mapgears
www.mapgears.com
