[OpenLayers-Users] Switch to google layer set diff center then at other layers
Mikesamar tech at reumer.net
Thu Sep 4 15:58:27 EDT 2008
Christopher Schmidt-4 wrote:
> On Wed, Sep 03, 2008 at 12:51:35AM -0700, Mikesamar wrote:
>> Hello forum members,
>> I've a problem with google maps layers when integrated with other layer.
>> If
>> I switch between a layer to a google layer then the map gets a new center
>> and my markers are out of the view. If I switch to a non google maps
>> marker
>> then the center is allright again and the icons are back in view.
>> See my page at
>> http://tech.reumer.net/component/option,com_joomlamaps/Itemid,49/
>> The javascript generating the map is:
>> http://tech.reumer.net/components/com_joomlamaps/main/mapopenlayers.js
> http://faq.openlayers.org/google/why-does-the-map-move-to-the-southeast-when-i-switch-to-a-google-maps-layer/
> So, your options are:
>  * Upgrade to SVN
>  * Wait for 2.7.
I've tested it on it works allmost.
First time a google layer is selected then it still centers wrong. Selecting
a other google layer the markers are back in view and is the center
allright. But the first layer stays wrong!
I only replaced the google.js file.
Regards Mike
View this message in context: http://www.nabble.com/Switch-to-google-layer-set-diff-center-then-at-other-layers-tp19277367p19318774.html
