[OpenLayers-Users] Measure tool in 2.7 RC1
Adams chris at genieknows.com
Sun Sep 7 19:06:03 EDT 2008
Keep in mind that at that zoom level, the width of the road is much more than is shown there.
The polygon that represents that area, was most likely constructed out of street intersections, i.e. the centre of the roads.. just so it looks better.
If you switched to satellite view you could probably get a better estimate with the measurement tool.
----- Original Message -----
From: "Jennifer Strahan" <jennifer at greeninfo.org>
To: users at openlayers.org
Sent: Sunday, September 7, 2008 3:03:56 PM (GMT-0400) America/Glace_Bay
Subject: [OpenLayers-Users] Measure tool in 2.7 RC1
Hello,
Thanks for including the measuring tool!  I'm wondering if there are any
guidelines for use that I should follow.  I added a Google map layer to
the measure example and am finding some error with the measurements.  Is
it possible that my map settings are wrong?
I measured Alamo Square in San Francisco and the area result is around
92557 square meters (nearly 23 acres).  The actual measurement should be
around 13 acres.
My test map is here:
http://www.parkinfo.org/review/measure.html
Any suggestions as to how I can adjust my settings to get the correct
results?
Thanks,
Jennifer
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
