[OpenLayers-Users] IE6 requests FORMAT=image/GIF - solved
Lehtonen, Mika mika at digikartta.net
Mon Sep 8 05:56:30 EDT 2008
Sorry,
that isn't totally right. That layer definition doesn't work in any
browser of mine. The key factor is having it as an overlay layer. As a
base layer it works. So it seems that the only solution to have an
overlay layer with regions' opacity set, is to use png and
'alpha:true'-setting. I can provide you a live example of this problem,
if you like. If this is true, I'll be better off by just announcing:
"Dont try this with IE6.". Yet so many people are still using Windows
2000 and IE.
- mika -
Lehtonen, Mika kirjoitti:
> Hi Christopher and others,
> I have this in my code and can't get the opacity work in IE6.
> var ronko2 = new OpenLayers.Layer.WMS(
>             "Kaava-alueet",
> "http://karsamaki.digikartta.net/asemakaavat/wms",
>                 {layers: 'dikanet:karsa_region,dikanet:karsa_text',
> format:'image/gif',transparent:true}, {maxExtent: bounds,
> isBaseLayer:false, resolutions: [5.66154, 2.8308, 1.132308, 0.56615,
> 0.28308, 0.1132308]});
> What's wrong with the code? OL is 2.6. Wms-server is Geoserver and in
> there, the SLD says that the opacity of the polygons should be 0.2.
> Works in IE7 and FF2-3.
> - mika -
> Christopher Schmidt kirjoitti:
>> On Fri, Sep 05, 2008 at 05:43:00PM +0300, Lehtonen, Mika wrote:
>>> And that would work in IE6 with layer format to set image/gif?
>>> - mika -
>> Should.
>> Regards,
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
