[OpenLayers-Users] Highlighting the selected geometry
Lehtonen, Mika mika at digikartta.net
Tue Sep 9 08:33:54 EDT 2008
Ok,
thanks for the hint. I will still try to do this without vector layer,
like Brad Spencer suggested.
cheers,
- mika -
Alexandre Dube kirjoitti:
> Hi Mika,
> If your 'other one' layer is vector, you might what to check this
> example : http://openlayers.org/dev/examples/select-feature.html
> It might have what you seek : a select feature control. Just
> right-click and "view page source" to see the code.
> Cheers,
> Alexandre
> Lehtonen, Mika wrote:
>> Hi,
>> is there any examples available which I could use with the following
>> task? Tried to google, but didn't find any good ones.
>> I have two wms-layers in my map. The another one includes some
>> polygons. In order to get some info out when clicking the polygon, I
>> built a system which does that. But I would also like to get the
>> selected polygon to render with a different style, so that it'd be
>> sort of highlighted. I thought I could copy it into vector layer
>> having different style. But frankly said, I don't know how to do it.
>> Just learning OL.
>> - mika -
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
