[OpenLayers-Users] VectorLayer disappears at zoom 17 (and lesser).
Erik Uzureau euzuro at gmail.com
Fri Sep 12 13:53:51 EDT 2008
Hello BrainDrain, Thank you for verifying the functionality of this feature.
Andreas put the fix in this morning and I have brought it up to the branch
just now, so yes it will be part of the 2.7 release. You can test the
2.7 rc2 here:
http://openlayers.org/download/OpenLayers-2.7-rc2.tar.gz
thanks for your help!
erik
On Fri, Sep 12, 2008 at 2:49 AM, BrainDrain <paulborodaev at gmail.com> wrote:
> Thank you very much!
> patch works great!
> Could we expect that it will be included in 2.7 final?
> Andreas Hocevar-3 wrote:
>> BrainDrain and Salvaro,
>> I created a ticket for this:
>> http://trac.openlayers.org/ticket/1732
>> Can you please apply the patch in this ticket and see if it resolves
>> the issue? Or just replace lib/OpenLayers/Renderer/VML.js with the
>> contents of the attached zip file?
>> Thanks!
>> On Thu, Sep 11, 2008 at 8:44 AM, BrainDrain <paulborodaev at gmail.com>
>> wrote:
>>> problem still exists in 2.7-rc1
>>> vectors disappears
>>> my solutions to avoid integer overflow in vml.js
>>> input proj
>>> "+proj=tmerc +lat_0=0 +lon_0=45 +k=1.000000 +x_0=0 +y_0=0 +ellps=krass
>>> +towgs84=23.92,-141.27,-80.9,0,0,0,0 +units=mm +no_defs"),
>>> need this output proj:
>>> "+proj=tmerc +lat_0=48.70975 +lon_0=44.51205 +k=1.000000 +x_0=0 +y_0=0
>>> +ellps=krass +towgs84=23.92,-141.27,-80.9,0,0,0,0 +units=m +no_defs"
>>> to fix problem I use output proj with offsets:
>>> "+proj=tmerc +lat_0=48.70975 +lon_0=44.51205 +k=1.000000 +x_0=-20000
>>> +y_0=5000000 +ellps=krass +towgs84=23.92,-141.27,-80.9,0,0,0,0 +units=m
>>> +no_defs"
>>> (as you can see, in my case: x-offset =-20000  y-offset=5000000)
>>> maybe It's possible to use dd units (lonlat proj) but im my case
>>> reprojection from mm(m) to dd produces
>>> unacceptable features geometry
>>> euzuro wrote:
>>>> Yes, please give the 2.7-rc1 a try... this should be fixed.
>>>> You can get it here:
>>>> http://openlayers.org/api/2.7-rc1/OpenLayers.js
>>>> ...the final release should be out in a couple of weeks.
>>>> Erik
>>>> On Wed, Sep 10, 2008 at 8:33 AM, Christopher Schmidt
>>>> <crschmidt at metacarta.com> wrote:
>>>>> On Wed, Sep 10, 2008 at 06:32:14AM -0700, BrainDrain wrote:
>>>>>> I think this can be related to this
>>>>>> http://www.nabble.com/integer-overflow-while-drawing-vectors%2C-help%21-td19085568.html
>>>>>> I use vector layer for measurement and my vectors disappears starting
>>>>>> from
>>>>>> some zoom scale (depends of how many zoom levels you have).
>>>>>> But I fix this only by bring some 'false' offset parameters in my
>>>>>> output
>>>>>> projection((
>>>>> Try 2.7-rc1 and see if it fixes the problem.
>>>>> Regards,
>>>>> Christopher Schmidt
>>>>> MetaCarta
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org
>>>>> http://openlayers.org/mailman/listinfo/users
>>>> Users mailing list
>>> View this message in context:
>>> http://www.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp19411610p19428805.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Users mailing list
> View this message in context: http://www.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp19411610p19451218.html
> Users mailing list
