[OpenLayers-Users] Jumping map while panning in Internet Explorer
Linda_Rawson linda.rawson at gmail.com
Mon Sep 15 23:42:03 EDT 2008
Did you find a solution to this problem?
Thanks,
Linda Rawson
Stephen Lee-8 wrote:
> Hi there,
> I need help solving this problem I had while panning the map in Internet
> Explorer, the nature of the problem is this:
> I have a webpage that contain the map div within a Tabcontrol from ASP
> Ajax
> Toolkit, when view in Firefox, everything went well, but under Internet
> Explorer, sometimes (especially when I refresh the page), the Openlayers
> start to encounter problem. The nature of the problem is that somehow
> sometimes, the map is not loaded properly, causing the Pan function to
> misbehave: when panning, it pan to invalid places. I have hosted the
> webpage
> at this address: http://www.tmavl.com/test.aspx. Currently the only
> solution
> I had is to place the map div outside the TabControl, can anyone help me
> to
> identify the cause of this? I have attached the source code in this email.
> If you can't simulate the error on first try, try refreshing the test.aspx
> a
> few times, gmail does not allow me to attached the test.aspx.vb file, but
> its empty anyway.
> My test environment:
>    - Openlayers 2.6
>    - IE 7
>    - Firefox 3.01
>    - ASP.Net
> Thanks in advance, I'm currently really at the end of my wits, appreciate
> any suggestion or help.
> Best regards,
> Stephen
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Jumping-map-while-panning-in-Internet-Explorer-tp19261638p19504811.html
