[OpenLayers-Users] Fwd: Jumping map while panning in Internet Explorer
Stephen Lee stephenljk at gmail.com
Tue Sep 16 21:31:00 EDT 2008
---------- Forwarded message ----------
Date: Wed, Sep 17, 2008 at 9:30 AM
Subject: Re: [OpenLayers-Users] Jumping map while panning in Internet
Explorer
To: Erik Uzureau <euzuro at gmail.com>
thanks Erik for the tip, will test it out right away. Linda, once tested
will forward the result to you. Thanks again for the help.
On Tue, Sep 16, 2008 at 2:10 PM, Erik Uzureau <euzuro at gmail.com> wrote:
> Things that come to mind are css attributes on the containing DOMElements
> like 'margin', 'padding', etc.
> I would suggest trying with the latest RC from the 2.7 branch. We are
> within a
> couple of weeks of doing the 2.7 final release, and it contains a fix for
> the
> aforementioned 'container-css' problem.
> http://openlayers.org/api/2.7-rc2/OpenLayers.js
> e
> On Mon, Sep 15, 2008 at 10:42 PM, Linda_Rawson <linda.rawson at gmail.com>
> wrote:
> > Did you find a solution to this problem?
> > Thanks,
> > Linda Rawson
> > Stephen Lee-8 wrote:
> >> Hi there,
> >> I need help solving this problem I had while panning the map in Internet
> >> Explorer, the nature of the problem is this:
> >> I have a webpage that contain the map div within a Tabcontrol from ASP
> >> Ajax
> >> Toolkit, when view in Firefox, everything went well, but under Internet
> >> Explorer, sometimes (especially when I refresh the page), the Openlayers
> >> start to encounter problem. The nature of the problem is that somehow
> >> sometimes, the map is not loaded properly, causing the Pan function to
> >> misbehave: when panning, it pan to invalid places. I have hosted the
> >> webpage
> >> at this address: http://www.tmavl.com/test.aspx. Currently the only
> >> solution
> >> I had is to place the map div outside the TabControl, can anyone help me
> >> to
> >> identify the cause of this? I have attached the source code in this
> email.
> >> If you can't simulate the error on first try, try refreshing the
> test.aspx
> >> a
> >> few times, gmail does not allow me to attached the test.aspx.vb file,
> but
> >> its empty anyway.
> >> My test environment:
> >>    - Openlayers 2.6
> >>    - IE 7
> >>    - Firefox 3.01
> >>    - ASP.Net
> >> Thanks in advance, I'm currently really at the end of my wits,
> appreciate
> >> any suggestion or help.
> >> Best regards,
> >> Stephen
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > View this message in context:
> http://www.nabble.com/Jumping-map-while-panning-in-Internet-Explorer-tp19261638p19504811.html
> > Sent from the OpenLayers Users mailing list archive at Nabble.com.
> > Users mailing list
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080917/b36753d7/attachment.html
