[OpenLayers-Users] Change color on a feature?
Alexandre Dube adube at mapgears.com
Wed Sep 17 09:02:18 EDT 2008
Hi Swärd,
  Here's a simple example of how it can be done.  ( Note that I just
copied/pasted some of my code and changed some parts of it so it might
have some errors, but the objective here is to make you understand how I
did it )...
  The following will work with a selectFeature Control activated and a
html <select> element of colors.  Let's say you have some drawn
features.  Select one, then select a color from the <select> menu...  It
will redraw your selected feature with the chosen color.
Hope this helps,
Alexandre
<!-- HTML PART -->
<select id="colors" onchange="drawFeatureUsingColor(this.value);">
     <option value="purple">purple</option>
     <option value="blue">blue</option>
     <option value="yellow">yellow</option>
     <option value="red">red</option>
     <option value="orange">orange</option>
     <option value="green">green</option>
</select>
// JS PART
aColors = {
    'purple': { fillColor:"purple" },
    'blue'  : { fillColor:"blue" },
    'yellow': { fillColor:"yellow" },
    'red'   : { fillColor:"red" },
    'orange': { fillColor:"orange" },
    'green' : { fillColor:"green" }
function drawFeatureUsingColor(szColor){
    // get current selected feature
    oFeature = olWFS.events.listeners.featureselected[0].obj.feature;
    // draw the feature with chosen color
    olWFS.drawFeature(oFeature, aColors[szColor]);
Swärd Mårten wrote:
> Hello!
> Is it possible to change the color of a feature that is already drawn
> to the map?
> If so, how do I do it? J
> I have a WFS layer and I need to change the colors of the feature
> depending of values that the user decides..
> *Mvh:*
> Mårten Swärd
> Systemutvecklare/Webbutvecklare, ITs
> SMHI, Sveriges Meteorologiska och Hydrologiska Institut
> Tel: +46 11 495 8469
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
