[OpenLayers-Users] VectorLayer disappears at zoom 17 (and lesser).
Salvaro asufsc at gmail.com
Thu Sep 18 09:15:34 EDT 2008
I did it (upgraded to the OL 2.7).
But the problem with vectorLayer continues.
It's still appearing with WMS and in the Google Maps with
sphericalMecator=false (with the known problem when pan), but when I set
sphericalMercator=true, the vectorLayer disappears and only appears on the
zoom level 17 (I'm using 19 levels)..
Thanks,
Salvaro.
Andreas Hocevar-2 wrote:
> Salvaro wrote:
>> Andreas,
>> Is this patch compatible with the OL 2.6?
> It won't apply to VML.js from 2.6, but if you walk through the hunks and
> apply them manually, it will work.
> Note, however, that there were many other vector rendering improvements
> between 2.6 and 2.7, so you might want to upgrade.
> Regards,
> Andreas.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp1079719p1098120.html
