[OpenLayers-Users] VectorLayer disappears at zoom 17 (and lesser).
Christopher Schmidt crschmidt at metacarta.com
Thu Sep 18 09:20:25 EDT 2008
On Thu, Sep 18, 2008 at 06:15:34AM -0700, Salvaro wrote:
> I did it (upgraded to the OL 2.7).
> But the problem with vectorLayer continues.
> It's still appearing with WMS and in the Google Maps with
> sphericalMecator=false (with the known problem when pan), but when I set
> sphericalMercator=true, the vectorLayer disappears and only appears on the
> zoom level 17 (I'm using 19 levels)..
Please create/publish/share an HTML example that demonstrates this.
-- Chris
> Thanks,
> Salvaro.
> Andreas Hocevar-2 wrote:
> > Salvaro wrote:
> >> Andreas,
> >> Is this patch compatible with the OL 2.6?
> > It won't apply to VML.js from 2.6, but if you walk through the hunks and
> > apply them manually, it will work.
> > Note, however, that there were many other vector rendering improvements
> > between 2.6 and 2.7, so you might want to upgrade.
> > Regards,
> > Andreas.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> View this message in context: http://n2.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp1079719p1098120.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Christopher Schmidt
MetaCarta
