[OpenLayers-Users] Vectors with text
Linda_Rawson linda.rawson at gmail.com
Thu Sep 18 16:23:55 EDT 2008
I am trying to fold this into Openlayers 2.7 rc2 and having a devil of a
time.
Here is the files that I have changed:
Renderer/Element.js
Renderer/SVG.js
Renderer/VML.js
Geometry/Collection.js
Geometry/LinearRing.js
Geometry/Point.js
What else is there to make this work?
Do you have this working with the latest version?
Thanks,
Linda Rawson
Pierre GIRAUD wrote:
> You should be aware that this work is still in progress. This is the
> reason why it is in a sandbox.
> Of course the sandbox code differs from the trunk with some files
> added, what you correctly noticed.
> The easier way to get it working locally is to download the sandbox code :
> svn checkout http://svn.openlayers.org/sandbox/camptocamp/vectorSymbols/
> Once again, this code continues to evoluate, some bugs are fixed,
> functionnalities are added or removed. It won't be stable till it goes
> into trunk if it does.
> However, you can try it and I would be please if you can give feedback
> as far I as I am the developer of this code.
> Regards,
> Pierre
> On Dec 7, 2007 9:43 AM, Andy Dale <andy.dale at gmail.com> wrote:
>> Hi,
>> I want to be able to assign a label to a vector.  I have found the
>> following
>> example
>> http://dev.openlayers.org/sandbox/camptocamp/text/examples/vector-features-with-text.html
>> I cannot get it to work locally.  I have looked at the OpenLayers.js in
>> the
>> lib directory of the this example and found that i did not have the
>> following files:
>> Style.js
>> Rule.js
>> Rule/FeatureId.js
>> Rule/Logical.js
>> Rule/Comparison.js
>> Format/SLD.js
>> I downloaded these and then added them to the lib/OpenLayers.js jsfiles
>> array, but I still cannot get it working.
>> Can anyone point out what i am missing ??
>> Thanks in advance,
>> Andy
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Vectors-with-text-tp14208934p19560988.html
