[OpenLayers-Users] VectorLayer disappears at zoom 17 (and lesser).
Salvaro asufsc at gmail.com
Fri Sep 19 08:16:19 EDT 2008
After some tries (and clear the cache and all references to the previous
lib), the vectorLayer aparently is working (I not tested with reprojected
points (they're at LonLat 0,0 at this moment), thanks Christopher, Andreas
and BrainDrain.
But after this aparently the checkresize() of the Google Layer stopped to
"work" (the map is opening in a square on the "left-top-corner" of the
area). Now I'm trying to fix it.
Thanks,
Salvaro.
Christopher Schmidt-2 wrote:
> On Thu, Sep 18, 2008 at 07:15:52AM -0700, Salvaro wrote:
>> I've one problem to do this, as the another time I'm programming direct
>> in
>> Java with GWT+openlayers, and haven't a way to put it in a server with a
>> legible code.
> I don't care how the Javascript looks: I just want to see a live example.
> If you can make the map variable a global variable, that will also help.
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/VectorLayer-disappears-at-zoom-17-%28and-lesser%29.-tp1079719p1100701.html
