[OpenLayers-Users] framedcloud - 2.7rc2
Don Martin donm at alaska.net
Sun Sep 21 17:29:06 EDT 2008
Thanks for the pushback Arnd - where are you inserting the body{} tag?
Arnd Wippermann wrote:
> If you prevent the wrapping of text, the popup are shown in IE6 without
> the
> scrollbar. Why it is different between 2.6 and 2.7, and IE and FF, I have
> no
> idea.
> body{
>     white-space:nowrap;
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Don Martin
> Gesendet: Sonntag, 21. September 2008 00:13
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] framedcloud - 2.7rc2
> the issue is most apparent in IE6 - the extra space with 2.6 isn't a
> concern
> (not showing extra space in .aspx file actually) - it is the wrapping of
> rows and the addition of the vertical scroll bar with 2.7rc2.
> in FF 2.0 there is some extra space in the lower portion of the box with
> 2.6
> (which isn't a biggie) and appears to function properly with 2.7rc2.
> Christopher Schmidt-4 wrote:
>> On Sat, Sep 20, 2008 at 12:17:46PM -0700, Don Martin wrote:
>>> Hi Eric,
>>> here are links to demo issue:
>>> ol 2.6 -
>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test26.htm
>>> ol 2.7rc2 -
>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test27.htm
>>> I can provide the page code instead if that would be more useful.
>> So, what I see in:
>>  * Safari3
>>  * FF2
>>  * FF3
>> Is that in 2.7, the popups size almost exactly right: there is no
>> extra border. In 2.6, the popup is twice as 'tall' as the content.
>> Which browser are you using?
>>> Don
>>> euzuro wrote:
>>> > Hi Don,
>>> > Thanks for the report. Can you provide a link that shows this (lack
>>> > of) functionality?
>>> > It is hard to take action given what you've described here.
>>> > Cheers,
>>> > Erik
>>> > On Fri, Sep 12, 2008 at 7:31 PM, Don Martin <donm at alaska.net> wrote:
>>> >> we're using framedcloud popups over a gml layer (hover) which
>>> >> worked
>>> fine
>>> >> with 2.6 but doesn't seem to be autosizing (width) with 2.7rc2 -
>>> >> it's wrapping rows and adding a vertical scroll bar.
>>> >> I was going to try 2.7 to attempt to get zoom-to-extent from the
>>> >> GML layer.
>>> >> Can I get extents with 2.6?
>>> >> suggestions on autosize issue?
>>> >> View this message in context:
>>> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19466263.htm
>>> >> l Sent from the OpenLayers Users mailing list archive at
>>> >> Nabble.com.
>>> >> _______________________________________________
>>> >> Users mailing list
>>> >> Users at openlayers.org
>>> >> http://openlayers.org/mailman/listinfo/users
>>> > Users mailing list
>>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19588342.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>> Christopher Schmidt
>> MetaCarta
>> Users mailing list
> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19589538.html
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19598670.html
