[OpenLayers-Users] framedcloud - 2.7rc2
Don Martin donm at alaska.net
Sun Sep 21 19:56:51 EDT 2008
OK - gotya - not a solution in my case though thanks.
Arnd Wippermann wrote:
>     <style type="text/css">
> body{
>     white-space:nowrap;
>         #map {
>             width: 800px;
>             height: 600px;
>             border: 1px solid black;
>     </style>
> It's only thought to show the influence of this css-parameter, because in
> this way the parameter works for all text of the htmlside. Perhaps also
> for
> text where the break is wanted.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von Don Martin
> Gesendet: Sonntag, 21. September 2008 23:29
> An: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] framedcloud - 2.7rc2
> Thanks for the pushback Arnd - where are you inserting the body{} tag?
>> If you prevent the wrapping of text, the popup are shown in IE6
>> without the scrollbar. Why it is different between 2.6 and 2.7, and IE
>> and FF, I have no idea.
>> body{
>>     white-space:nowrap;
>> Arnd Wippermann
>> [mailto:users-bounces at openlayers.org] Im Auftrag von Don Martin
>> Gesendet: Sonntag, 21. September 2008 00:13
>> the issue is most apparent in IE6 - the extra space with 2.6 isn't a
>> concern (not showing extra space in .aspx file actually) - it is the
>> wrapping of rows and the addition of the vertical scroll bar with
>> 2.7rc2.
>> in FF 2.0 there is some extra space in the lower portion of the box
>> with
>> 2.6
>> (which isn't a biggie) and appears to function properly with 2.7rc2.
>> Christopher Schmidt-4 wrote:
>>> On Sat, Sep 20, 2008 at 12:17:46PM -0700, Don Martin wrote:
>>>> Hi Eric,
>>>> here are links to demo issue:
>>>> ol 2.6 -
>>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test26.htm
>>>> ol 2.7rc2 -
>>>> http://maps.dispatchsys.com/dispatch_map/test_map/ol_test27.htm
>>>> I can provide the page code instead if that would be more useful.
>>> So, what I see in:
>>>  * Safari3
>>>  * FF2
>>>  * FF3
>>> Is that in 2.7, the popups size almost exactly right: there is no
>>> extra border. In 2.6, the popup is twice as 'tall' as the content.
>>> Which browser are you using?
>>>> Don
>>>> euzuro wrote:
>>>> > Hi Don,
>>>> > Thanks for the report. Can you provide a link that shows this
>>>> > (lack
>>>> > of) functionality?
>>>> > It is hard to take action given what you've described here.
>>>> > Cheers,
>>>> > Erik
>>>> > On Fri, Sep 12, 2008 at 7:31 PM, Don Martin <donm at alaska.net> wrote:
>>>> >> we're using framedcloud popups over a gml layer (hover) which
>>>> >> worked
>>>> fine
>>>> >> with 2.6 but doesn't seem to be autosizing (width) with 2.7rc2 -
>>>> >> it's wrapping rows and adding a vertical scroll bar.
>>>> >> I was going to try 2.7 to attempt to get zoom-to-extent from the
>>>> >> GML layer.
>>>> >> Can I get extents with 2.6?
>>>> >> suggestions on autosize issue?
>>>> >> View this message in context:
>>>> >> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19466263.ht
>>>> >> m l Sent from the OpenLayers Users mailing list archive at
>>>> >> Nabble.com.
>>>> >> _______________________________________________
>>>> >> Users mailing list
>>>> >> Users at openlayers.org
>>>> >> http://openlayers.org/mailman/listinfo/users
>>>> > Users mailing list
>>>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19588342.html
>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>> Users mailing list
>>> Christopher Schmidt
>>> MetaCarta
>>> Users mailing list
>> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19589538.html
>> Users mailing list
>> Users mailing list
> http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19598670.html
> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/framedcloud---2.7rc2-tp19466263p19599836.html
