[OpenLayers-Users] GeoRSS question
Deli Soetiawan crushfire2004 at gmail.com
Sun Sep 21 21:29:42 EDT 2008
thanks for your help, i've notice that was a reloading function using
SetInterval
[i]setInterval(reload, 5000);[/i], and i think this function built-in on
OpenLayers so it will not make a problem
for browser cache thing, i could use php with transsid enable and regenerate
session every data reload, or like you have said before we could use
random_seed in our browser using JS (nicely done) :D
and thanks for confirming vector draw (line, polygon), now i should use GML
layer with GeoRSS format :D
Christopher Schmidt-4 wrote:
> On Fri, Sep 19, 2008 at 04:06:06PM +0700, Deli Soetiawan wrote:
>> Hi list,
>> I have some questions about GeoRSS thing in OpenLayers (2.6):
>> 1. How to set GeoRSS layer to reload data after specified interval,
>> example i want to reload my GeoRSS layer every 2 minutes, currently i use
>> php generated georss as url, something like:
>> rssPoints = new OpenLayers.Layer.GeoRSS('GeoRSS','georss.php');
> http://crschmidt.net/mapping/geojson-reload.html
> Since browser cache things, you probably want to also stick a
> "url?random_seed=" + Math.random() on there.
>> 2. Is georss layers support for line & polygon drawing? or i need to use
>> GML layer instead?
> Yes, you would use a GML layer with a GeoRSS format.
>> 4. GeoRSS vs GML vs KML layer, which better for starter? i currently use
>> GeoRSS since it really easy for the markup to write, but since GML output
>> and GeoRSS output was .xml maybe i should move to GML/KML...
> 1. There is no KML layer. (If you look at the 'kml-layer' example, you'll
>    see that it's just a GML layer.)
> 2. In the same way that there is no KML layer, you can also use GeoRSS
>    with a "Layer.GML", and it will draw using vectors, which means you
>    will get your points/lines/polys.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/GeoRSS-question-tp19568795p19600491.html
