[OpenLayers-Users] marker label?
Linda_Rawson linda.rawson at gmail.com
Thu Sep 25 10:57:33 EDT 2008
I do this by changing marker.js.   When they mouse over they see the text.
MarkerLayer.addMarker(new OpenLayers.Marker(new
OpenLayers.LonLat(longitude,latitude), icon, theID, theTitle));
/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
 * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for
the
 * full text of the license. */
 * @requires OpenLayers/Events.js
 * @requires OpenLayers/Icon.js
 * Class: OpenLayers.Marker
 * Instances of OpenLayers.Marker are a combination of a
 * <OpenLayers.LonLat> and an <OpenLayers.Icon>.
 * Markers are generally added to a special layer called
 * <OpenLayers.Layer.Markers>.
 * Example:
 * (code)
 * var markers = new OpenLayers.Layer.Markers( "Markers" );
 * map.addLayer(markers);
 * var size = new OpenLayers.Size(10,17);
 * var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
 * var icon = new
OpenLayers.Icon('http://boston.openguides.org/markers/AQUA.png',size,offset);
 * markers.addMarker(new OpenLayers.Marker(new
OpenLayers.LonLat(0,0),icon));
OpenLayers.LonLat(0,0),icon.clone()));
 * (end)
 * Note that if you pass an icon into the Marker constructor, it will take
 * that icon and use it. This means that you should not share icons between
 * markers -- you use them once, but you should clone() for any additional
 * markers using that same icon.
OpenLayers.Marker = OpenLayers.Class({
     * Property: id
     * {String}
     * Property: icon
     * {<OpenLayers.Icon>} The icon used by this marker.
    icon: null,
     * Property: lonlat
     * {<OpenLayers.LonLat>} location of object
    lonlat: null,
     * Property: events
     * {<OpenLayers.Events>} the event handler.
    events: null,
     * Property: map
     * {<OpenLayers.Map>} the map this marker is attached to
    map: null,
    txtDiv: null,
    markerText: null,
     * Constructor: OpenLayers.Marker
     * Paraemeters:
     * icon - {<OpenLayers.Icon>}  the icon for this marker
     * lonlat - {<OpenLayers.LonLat>} the position of this marker
    initialize: function(lonlat, icon, id, title) {
        this.lonlat = lonlat;
        this.id = id;
        this.markerText = title;
        var newIcon = (icon) ? icon : OpenLayers.Marker.defaultIcon();
        if (this.icon == null) {
            this.icon = newIcon;
        } else {
            this.icon.url = newIcon.url;
            this.icon.size = newIcon.size;
            this.icon.offset = newIcon.offset;
            this.icon.calculateOffset = newIcon.calculateOffset;
        this.txtDiv = document.createElement('div');
        this.txtDiv.style.backgroundColor = '#F0E68C';
        this.txtDiv.style.display = 'none';
        this.txtDiv.style.whiteSpace = 'nowrap';
        this.txtDiv.style.position = 'relative';
        this.icon.imageDiv.appendChild(this.txtDiv);
        this.events = new OpenLayers.Events(this, this.icon.imageDiv, null);
        this.events.register("mouseover", this, this.divMouseOver);
        this.events.register("mouseout", this, this.divMouseOut);
     * APIMethod: destroy
     * Destroy the marker. You must first remove the marker from any
     * layer which it has been added to, or you will get buggy behavior.
     * (This can not be done within the marker since the marker does not
     * know which layer it is attached to.)
    destroy: function() {
        this.map = null;
        this.events.destroy();
        this.events = null;
        if (this.icon != null) {
            this.icon.destroy();
            this.icon = null;
    * Method: draw
    * Calls draw on the icon, and returns that output.
    * Parameters:
    * px - {<OpenLayers.Pixel>}
    * Returns:
    * {DOMElement} A new DOM Image with this marker's icon set at the
    * location passed-in
    draw: function(px) {
        //this.txtDiv.style.position = 'absolute';
        //this.txtDiv.top = (px.y - 5) + 'px';
        //this.txtDiv.left = px.x + 'px';
        return this.icon.draw(px);
    * Method: moveTo
    * Move the marker to the new location.
    * Parameters:
    * px - {<OpenLayers.Pixel>} the pixel position to move to
    moveTo: function (px) {
        if ((px != null) && (this.icon != null)) {
            this.icon.moveTo(px);
        this.lonlat = this.map.getLonLatFromLayerPx(px);
     * Method: onScreen
     * Returns:
     * {Boolean} Whether or not the marker is currently visible on screen.
    onScreen:function() {
        var onScreen = false;
        if (this.map) {
            var screenBounds = this.map.getExtent();
            onScreen = screenBounds.containsLonLat(this.lonlat);
        return onScreen;
     * Method: inflate
     * Englarges the markers icon by the specified ratio.
     * Parameters:
     * inflate - {float} the ratio to enlarge the marker by (passing 2
     *                   will double the size).
    inflate: function(inflate) {
        if (this.icon) {
            var newSize = new OpenLayers.Size(this.icon.size.w * inflate,
                                              this.icon.size.h * inflate);
            this.icon.setSize(newSize);
     * Method: setOpacity
     * Change the opacity of the marker by changin the opacity of
     *   its icon
     * Parameters:
     * opacity - {float}  Specified as fraction (0.4, etc)
    setOpacity: function(opacity) {
        this.icon.setOpacity(opacity);
     * Method: setUrl
     * Change URL of the Icon Image.
     * url - {String}
    setUrl: function(url) {
        this.icon.setUrl(url);
     * Method: display
     * Hide or show the icon
     * display - {Boolean}
    display: function(display) {
        this.icon.display(display);
    divMouseOver: function (evt) {
        this.txtDiv.innerHTML = this.markerText;
        this.txtDiv.style.display = '';
    divMouseOut: function (evt) {
    CLASS_NAME: "OpenLayers.Marker"
 * Function: defaultIcon
 * Creates a default <OpenLayers.Icon>.
 * Returns:
 * {<OpenLayers.Icon>} A default OpenLayers.Icon to use for a marker
OpenLayers.Marker.defaultIcon = function() {
    var url = OpenLayers.Util.getImagesLocation() + "marker.png";
    var size = new OpenLayers.Size(21, 25);
    var calculateOffset = function(size) {
                    return new OpenLayers.Pixel(-(size.w/2), -size.h);
    return new OpenLayers.Icon(url, size, null, calculateOffset);
Linda Rawson
Deli Soetiawan wrote:
> Hi list,
> Formerly i use Ka-Map as my WebGIS engine together with their XML Overlay,
> since now i have migrated into OpenLayers and using GML Layer + GeoRSS
> Format, but seems OL can't (instantly) display label from georss where as
> Ka-Map capable to do that.
> Is there any way to add label(s) below the marker(s)?
> Thanks,
> Deli Soetiawan
View this message in context: http://www.nabble.com/marker-label--tp19664832p19671300.html
