[OpenLayers-Users] Slow performance when zooming in to large vector object in IE
Zer hcan at hotmail.com
Thu Sep 25 16:05:55 EDT 2008
I've tried 2.7 RC3 now. No change. IE still hangs for up to 1 min.
-Z
Zer wrote:
> Hi Andreas,
> Unfortunately, I can not provide a public link for the moment, I could
> create a code snippet and a GML file if that could help.
> I am using 2.6 and in this case is it just one (1) vector! I will give 2.7
> a try asap in report back.
> -Z
> Andreas Hocevar-3 wrote:
>> Can you provide a public accessible demo?
>> Also, it would be interesting to know which version of OpenLayers you
>> are using. Version 2.7 (currently at release candidate 2) has several
>> improvements here, compared to 2.6.
>> If you can render your vectors on a server, then do that. If you need
>> mouseover effects and other interaction on the map, it is probably ok to
>> render vectors on the client. Also, as a rule of thumb, if the number of
>> features/vertices goes up to the 1000s, things are likely to get slow,
>> especially in IE.
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Slow-performance-when-zooming-in-to-large-vector-object-in-IE-tp19540424p19677261.html
