[OpenLayers-Users] Slow performance when zooming in to large vector object in IE
Andreas Hocevar ahocevar at opengeo.org
Thu Sep 25 16:10:40 EDT 2008
Zer wrote:
> I've tried 2.7 RC3 now. No change. IE still hangs for up to 1 min.
If you can provide a GML file and the snippet with your map and layer
setup, that would help. Interesting questions are:
 * what projection are you using?
 * what is the bounding box of the offending vector?
I suspect you have a polygon with a huge bounding box in a projection
with meter (or smaller) units.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
