[OpenLayers-Users] Can't get VE map to work
realjax jax at schildmos.nl
Fri Sep 26 07:56:05 EDT 2008
euzuro wrote:
> Yup,
> The problem is that you are requestion v6.1 of the VE library, and yet you
> are
> requesting the current API version of OpenLayers... which is v2.6.
As a side note it may be interesting to know that microsoft recently
'deprecated' all versions prior to 6. In effect this means that currently
*only* version 2.7 works correctly with VE.
View this message in context: http://www.nabble.com/Can%27t-get-VE-map-to-work-tp19481251p19687019.html
