[OpenLayers-Users] Can't get VE map to work
Erik Uzureau euzuro at gmail.com
Sun Sep 28 03:22:46 EDT 2008
This is a good point. I'll try to remember to make a note of this on the FAQ
thanks!
On Fri, Sep 26, 2008 at 7:56 AM, realjax <jax at schildmos.nl> wrote:
> euzuro wrote:
>> Yup,
>> The problem is that you are requestion v6.1 of the VE library, and yet you
>> are
>> requesting the current API version of OpenLayers... which is v2.6.
> As a side note it may be interesting to know that microsoft recently
> 'deprecated' all versions prior to 6. In effect this means that currently
> *only* version 2.7 works correctly with VE.
> View this message in context: http://www.nabble.com/Can%27t-get-VE-map-to-work-tp19481251p19687019.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
