[OpenLayers-Users] Associate Marker with its popup after drag
Bijoy bijoya at rediff.co.in
Mon Sep 29 01:58:33 EDT 2008
Hey All,
I have tried lots of ways... and, unfortunately, I am not able to crack
this. Can anyone help me with below query, if this can be done.
Thanks.
<BIJOY>
Bijoy wrote:
> Hi All,
> I hope someone can help me with this.
> I am developing a map service where user can click on any point on the
> map,
> and the marker shows with its popup. User can than fill up the form and
> submit. This marker now contains the saved data.
> Now, user can also drag this marker to new location if he wants to and
> re-position the marker to new location. The already saved data should now
> show on the popup with new lonlat position of the markers. The user can
> put
> any number of markers, and drag any marker at any time.
> The problem I am facing here is how I associate the popup with its marker.
> I
> am using OpenLayer.Feature obj to createPopup and createMarker. And, to
> drag
> the marker, I am using DragMarker control. On 'doneDragging' I trap the
> new
> lonlat position. But, I can't associate the popup with this marker. If I
> could set any ID for each marker and If I could get this ID after drag, I
> could know that this marker is ID 1, and popup data should be Array 1
> [Something like this.].
> Or, If I could drag the popup along with marker. Right now, I destroy the
> earlier popup using feature.destroyPopup(), and redraw it again with new
> lotlan position which I am sure is not a good idea to do. There must be
> something which can be used to move the popup along with marker.
> I hope this explanation is good enough to know about the problem I face.
> Thanks,
> With Regards,
> <BIJOY>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Associate-Marker-with-its-popup-after-drag-tp19688063p19718668.html
