[OpenLayers-Users] Modify Feature Control does not select features
Sebastian Schmitz schmitz at geographie.uni-bonn.de
Mon Sep 29 05:29:25 EDT 2008
more problem description:
the described behavior applies only to vector features coming from a
WFS. If I draw the features onto the map previously things work out
nicely, but not on rendered WFS features. ???
Cheers
Sebastian
Sebastian Schmitz schrieb:
> Hi list,
> I use OpenLayers 2.6 and have trouble with the ModifyFeature Control.
> If I select a point for modifying, it does not get selected in the nice
> blue select style, but stays in the layers style.
> Debugging told me the modified feature is in fact displayed selected at
> some point (ModifyFeature.selectFeature(object): before
> this.resetVertices();) but then overridden by the layers default style
> (in the Vector drawFeature method as the feature lacks a style). The
> feature does neither have a style nor a renderIntent attached to it.
> Using the SelectFaeture Control on it's own without the ModifyFeature on
> the map, however, features do get selected nicely.
> What is worse: The modified feature disappears, when I select  another
> feature.
> Glad for any hint.
> Cheers
> Sebastian
> This is my code (the selectControl is used for :
> <html xmlns="http://www.w3.org/1999/xhtml">
>    <head>
>      <title>SelectFeature Control on Layer.Vector</title>
>      <link rel="stylesheet" href="../theme/default/style.css"
> type="text/css" />
>      <link rel="stylesheet" href="style.css" type="text/css" />
>      <style type="text/css">
>          #controlToggle li {
>              list-style: none;
>      </style>
>      <script src="../lib/OpenLayers.js"></script>
>      <script type="text/javascript"><!--
>          var map, drawControls, vectors;
>          OpenLayers.Feature.Vector.style['default']['strokeWidth'] = '2';
>          function init(){
>              map = new OpenLayers.Map('map', {controls: []});
>              var wmsLayer = new OpenLayers.Layer.WMS(
>                  "OpenLayers WMS",
>                  "http://labs.metacarta.com/wms/vmap0",
>                  {layers: 'basic'}
>              vectors = new OpenLayers.Layer.WFS(
>                  "Cities",
>                  "http://localhost:8080/geoserver/wfs",
>                  {typename: 'topp:tasmania_cities'},
>                      typename: "tasmania_cities",
>                      featureNS: "http://www.openplans.org/topp",
>                      featurePrefix: "topp",
>                      extractAttributes: false,
>                      commitReport: function(str) {
>                          OpenLayers.Console.log(str);
>              //new OpenLayers.Layer.Vector("Vector Layer");
>              map.addLayers([wmsLayer, vectors]);
>              map.addControl(new OpenLayers.Control.LayerSwitcher());
>              drawControls = {
>                  point: new OpenLayers.Control.DrawFeature(
>                      vectors, OpenLayers.Handler.Point,
>                      featureAdded : function(feature) {
>                  		feature.layer.eraseFeatures([feature]);
>                  		// cast to multipoint
>                  		feature.geometry = new
> OpenLayers.Geometry.MultiPoint(feature.geometry);
>                  		feature.state = OpenLayers.State.INSERT;
>                  		feature.layer.drawFeature(feature);
>                  line: new OpenLayers.Control.DrawFeature(
>                      vectors, OpenLayers.Handler.Path
>                  polygon: new OpenLayers.Control.DrawFeature(
>                      vectors, OpenLayers.Handler.Polygon
>                  /*select: new OpenLayers.Control.SelectFeature(
>                      vectors,
>                          clickout: false, toggle: false,
>                          multiple: false, hover: false,
>                          toggleKey: "ctrlKey", // ctrl key removes from
> selection
>                          multipleKey: "shiftKey", // shift key adds to
> selection
>                          onSelect: function(feature){
>                          	feature.state = OpenLayers.State.DELETE
>                   		onUnselect: function(feature){
>                   			feature.state = null
>                  selecthover: new OpenLayers.Control.SelectFeature(
>                      vectors,
>                          multiple: false, hover: true,
> selection
>                          multipleKey: "shiftKey" // shift key adds to
> selection
>                  save: new OpenLayers.Control.Button(
> 		                trigger: OpenLayers.Function.bind(vectors.commit,
> vectors),
> 		                displayClass: "olControlSaveFeature"
>              		modify: new OpenLayers.Control.ModifyFeature(
> 	            	vectors
> 	            		displayClass: "olControlModifyFeature",
> 		             	 onModificationStart: function(feature) {
> 		                 OpenLayers.Console.log("start modifying MODIFY",
> feature.id);
> 		                 onModification: function(feature) {
> 		                 OpenLayers.Console.log("modified MODIFY", feature.id);
> 		                 feature.state = OpenLayers.State.UPDATE;
> 		                 onModificationEnd: function(feature) {
> 		                 OpenLayers.Console.log("end modifying MODIFY",
> feature.id);
>              for(var key in drawControls) {
>                  map.addControl(drawControls[key]);
>              var panel = new OpenLayers.Control.Panel(
>                  {displayClass: 'olControlEditingToolbar'}
>              panel.addControls(
>                   drawControls['save'],drawControls['modify']
>              map.addControl(panel);
>              map.addControl(new OpenLayers.Control.MouseDefaults());
>              map.addControl(new OpenLayers.Control.MousePosition());
>              map.addControl(new OpenLayers.Control.PanZoom());
> 			map.zoomToExtent(new OpenLayers.Bounds(140.64,-44.42,151.89,-38.80));
>          function toggleControl(element) {
>              for(key in drawControls) {
>                  var control = drawControls[key];
>                  if(element.value == key && element.checked) {
>                      control.activate();
>                  } else {
>                      control.deactivate();
>          function update() {
>              var clickout = document.getElementById("clickout").checked;
>              drawControls.select.clickout = clickout;
>              var hover = document.getElementById("hover").checked;
>              drawControls.select.hover = hover;
>              drawControls.select.box =
> document.getElementById("box").checked;
>              if(drawControls.select.active) {
>                  drawControls.select.deactivate();
>                  drawControls.select.activate();
>      --></script>
>    </head>
>    <body onload="init()">
>      <h1 id="title">OpenLayers Select Feature Example</h1>
>      <p id="shortdesc">
>        Select a feature on hover or click with the Control.SelectFeature
> on a
>        vector layer.
>      </p>
>      <div id="map" class="smallmap"></div>
>      <ul id="controlToggle">
>          <li>
>              <input type="radio" name="type" value="none" id="noneToggle"
>                     onclick="toggleControl(this);" checked="checked" />
>              <label for="noneToggle">navigate</label>
>          </li>
>          <li>
>              <input type="radio" name="type" value="point" id="pointToggle"
>                     onclick="toggleControl(this);" />
>              <label for="pointToggle">draw point</label>
>          </li>
>          <li>
>              <input type="radio" name="type" value="line" id="lineToggle"
>              <label for="lineToggle">draw line</label>
>          </li>
>          <li>
>              <input type="radio" name="type" value="polygon"
> id="polygonToggle"
>              <label for="polygonToggle">draw polygon</label>
>          </li>
>          <li>
>              <input type="radio" name="type" value="selecthover" id="hover"
>              <label for="selecthoverToggle">Select features on hover</label>
>          </li>
>          <li>
>              <input type="radio" name="type" value="select"
> id="selectToggle"
>              <label for="selectToggle">select feature</label>
>              <ul>
>                  <li>
>                      <input id="box" type="checkbox" checked="checked"
>                             name="box" onchange="update()" />
>                      <label for="box">select features in a box</label>
>                  </li>
>                  <li>
>                      <input id="clickout" type="checkbox"
>                             name="clickout" onchange="update()" />
>                      <label for="clickout">click out to unselect
> features</label>
>                  </li>
>              </ul>
>          </li>
>      </ul>
>      <p>Use the shift key to select multiple features.  Use the ctrl key to
>      toggle selection on features one at a time.  Note: the "clickout"
> option has no
>      effect when "hover" is selected.</p>
>    </body>
> </html>
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
