[OpenLayers-Users] How to restrict map extent?
shymon
szymon.bogacz at o2.pl
Wed Apr 1 06:57:54 EDT 2009
Hello,
I'm trying to set up my own map app using OSM data, mapnik + PostGIS to render map, mod_tile to serve tiles and OpenLayers for map display. Everything works fine, except I cannot restrict viewable map area in OpenLayers. I want user to see only area of one city, and not to zoom out outside it.
So I have downloaded OSM XML file with map of requested area, loaded it to PostGIS with command like this:
osm2pgsql -d some-db -p some-prefix -U some-user -H localhost /neuromap/trunk/data/wroclaw-map.osm -c -E 900913 -b 16.8188,50.9974,17.2235,51.2065
(BTW: data is loaded to PostGIS but osm2pgsql says:
StartElement: Unknown element name: bounds
EndElement: Unknown element name: bounds - maybe this is a problem?)
I create OpenLayers map as follows:
var mapnikLayer = new OpenLayers.Layer.OSM("world", "http://some-url...");
var mapOptions = {
controls:[
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.Permalink(),
new OpenLayers.Control.ScaleLine(),
new OpenLayers.Control.OverviewMap(),
new OpenLayers.Control.Permalink('permalink'),
new OpenLayers.Control.MousePosition(),
new OpenLayers.Control.KeyboardDefaults(),
new OpenLayers.Control.MouseDefaults()
maxExtent: new OpenLayers.Bounds(1863611,6614478,1924760,6660340),
maxResolution: 0.6,
units: 'm',
//numZoomLevels: 19,
projection: new OpenLayers.Projection("EPSG:900913")
var map = new OpenLayers.Map ("wroc-map", mapOptions);
map.addLayer(mapnikLayer);
When I call map.zoomToMaxExtent(), OpenLayers shows what I expect to be whole world area - not my city. When I display map.getMaxExtent() i get:
max extent: left-bottom=(-20037508.34,-20037508.34) right-top=(20037508.34,20037508.34)
so maxExtent is evidently not set.
I can do of course:
map.zoomToExtent(new OpenLayers.Bounds(1863611,6614478,1924760,6660340))
but that's not what I want because zoom level is set to 11. I would prefer to have zl=0 with the view of whole city.
I also tried to use scales:[220000,150000,100000,50000,20000,10000,5000,2000,1000] instead of maxExtent and maxResolution, but though I call zoomToExtent... and viewport has this extent I can see only placeholder tile images with message "...more OSM data soon".
Is restricting of viewable map area possible?
What am I doing wrong?
Please help.
Shymon
View this message in context: http://n2.nabble.com/How-to-restrict-map-extent--tp2568378p2568378.html
