[OpenLayers-Users] Mapserver and Openlayers - Pink Tiles
Chris Adams
chris at genieknows.com
Wed Apr 15 12:08:28 EDT 2009
The path to the 'mapserv' application should be in fact a URL, which can
be accessed from any computer suitable for viewing the map. The path to
your map file is a file path within the server.
i.e.
layer = new OpenLayers.Layer.MapServer("MyMap","http://myserver/cgi-bin/mapserv", {map: "c:\maps\mymap.map"} );
sendeman wrote:
> Hi All,
> I'm new to Openlayers and Mapserver. I want to add a map generated by mapserver to my openlayers map. I have made a simple html-file in my http-root to test the openlayers/mapserver configuration (see below). The map file seems to work. I was able to generate an image with: shp2img -m mymap.map -o mymap.png (see below). When I open the example via localhost, I get a set of pink tiles and the requested map controls. I have added the location of one of the tile-images below. I also added the contents of the Mapserver map-file.
> I have tried lot's of different ways to spell out the url's in:
> layer = new OpenLayers.Layer.MapServer("MyMap","../../../bin/mapserv", {map: "../maps/mymap.map"} );
> , including using absolute paths (c:\...etc). This didn't make any difference.
> What should I do to get this working?
> I hope anyone can help me out. Any help will be appreciated.
> Best regards,
> Martijn Senden.
> p.s. On a sidenote: the opacity set on the shape in the map-file doesn't seem to be rendered. Any ideas?
> HTML-file:
> ========<CODE>========
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <style type="text/css">
> #map {
> width: 800px;
> height: 475px;
> border: 1px solid black;
> </style>
> <script src="http://openlayers.org/api/OpenLayers.js"></script>
> <script type="text/javascript">
> var map, layer;
> function init(){
> map = new OpenLayers.Map('map', {
> projection: "EPSG:28992",
> maxResolution: 1328.125,
> numZoomLevels: 14,
> maxExtent : new OpenLayers.Bounds(-23500,289000,316500,629000),
> units : "meters",
> controls: [
> new OpenLayers.Control.ZoomToMaxExtent(),
> new OpenLayers.Control.PanZoomBar({zoomWorldIcon: true}),
> new OpenLayers.Control.LayerSwitcher({'ascending':false}),
> new OpenLayers.Control.MousePosition(),
> new OpenLayers.Control.MouseDefaults(),
> new OpenLayers.Control.KeyboardDefaults()
> layer = new OpenLayers.Layer.MapServer( "MyMap",
> map.addLayer(layer);
> map.zoomToExtent(new OpenLayers.Bounds(83600,446000,84600,448200));
> </script>
> </head>
> <body onload="init()">
> <div id="map"></div>
> </body>
> </html>
> ========</CODE>========
> My server-root is:
> C:\OSGeo4W\
> The http-root is:
> C:\OSGeo4W\apps\geoviewer\htdocs\
> The map file is in:
> C:\OSGeo4W\apps\geoviewer\maps\
> The mapserv.exe is in:
> C:\OSGeo4W\bin\
> The map generated with shp2img:
> The Mapserverv map-file:
> MAP
> NAME MyMap
> STATUS on
> SIZE 900 600
> EXTENT 83600 446000 84600 448200
> UNITS meters
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> WEB
> IMAGEPATH "/OSGeo4W/apps/geoviewer/htdocs/images/maps/"
> IMAGEURL "images/maps/"
> LOG "/OSGeo4W/apps/geoviewer/maps/tmp/mapserver.log"
> END
> LEGEND
> TRANSPARENT true
> END
> SCALEBAR
> TRANSPARENT true
> END
> LAYER
> NAME Topografie
> TYPE raster
> STATUS on
> DATA "/OSGeo4W/apps/geoviewer/data/raster/MyRaster.tif"
> CLASS
> NAME "MyRaster"
> END
> END
> LAYER
> NAME Tunnel
> TYPE polygon
> STATUS on
> DATA "/OSGeo4W/apps/geoviewer/data/shp/MyShape.shp"
> CLASS
> NAME "MyShape"
> STYLE
> COLOR 197 194 194
> OPACITY 70
> OUTLINECOLOR 0 0 0
> END
> END
> END
> END
> Finally: the location of one the pink image files generated by OpenLayers:
> http://localhost/bin/mapserv?map=..%2Fmaps%2Fmymap.map&mode=map&map_imagetype=png&mapext=82750+447046.875+84078.125+448375&imgext=82750+447046.875+84078.125+448375&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
